Results 1 to 10 of 16
09-28-2012, 03:35 PM #1New Member
- Join Date
- Sep 2012
- Posts
- 13
- Location
- Silsbee, TX.
- Tractor
- Ford/3000 (Year 1966); Ford/9N
66 Ford 3000 Voltage Regulator
Hey y'all! Is there any way to check a voltage regulator to see if it is good or not? I have a 66 Ford 3000 diesel and the previous owner has by-passed the voltage regulator and none of the instruments work and I'm thinking that could be the culprit? Y'all got any advice? Or should I just go ahead and buy a $25.00 regulator! Lol!
Thanks!
Brad
09-28-2012, 03:54 PM #2
Re: 66 Ford 3000 Voltage Regulator
Why would they bypass the regulator?? If they did that, it either means that the battery isnt charging, or can be overcharging and potentially explode. Not good.
Personally, I would just drop the $25 for peice of mind. I dont remember exactally how to test them, but if it is working properly....it sould be buzzing/humming
Soundguy is about an expert on these. I am sure he will be along shortly.".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
09-28-2012, 05:41 PM #3Silver Member
- Join Date
- Aug 2009
- Posts
- 180
- Location
- loganville ga
- Tractor
- wheel horse c-100
can you describe what you mean with the regulator was by passed what did they do to accomplish this. your tractor should have come with a lucas generator with 6 terminal hook ups 2 which were b+ hook ups the rest are battery field and generator hook ups. by some chance has it been converted to the alternator type set up. if it still generator it should have a tach drive worm gear coming out of back
09-28-2012, 08:29 PM #4Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
regulator.. or stabalizer?
and hows the fuse inthe wire harness to the cluster?
10-01-2012, 10:10 AM #5New Member
- Join Date
- Sep 2012
- Posts
- 13
- Location
- Silsbee, TX.
- Tractor
It still has the generator system. Not sure about the fuse? I'm going to get into it soon. Haven't been able to play around with my tractor as of late due to some personal issues. As soon as I get the personal stuff under control I'll be back on the tractor! And the votage regulator/instrument cluster is on the top of my list! Guys, I can't thank y'all enough for the wise counsel and advice!
Thanks and God bless!
Brad
10-01-2012, 10:36 AM #6Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
again.. stabilizer or regulator.. makes a big difference....
10-01-2012, 10:49 AM #7New Member
- Join Date
- Sep 2012
- Posts
- 13
- Location
- Silsbee, TX.
- Tractor
Don't know Soundguy? I'll have to look at the part and see if I can read anything on it.
10-01-2012, 11:05 AM #8Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
forget that.. just see how it's hooekd up.. vstab is for the cluster.. vreg is for the genny.
2 completely different parts different jobs.. cause different issues...
10-01-2012, 03:30 PM #9New Member
- Join Date
- Sep 2012
- Posts
- 13
- Location
- Silsbee, TX.
- Tractor
10-01-2012, 03:37 PM #10Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
never mind.. you didn't read any of my replies obviously...
Similar Threads
Ford 1700 - Voltage Regulator replacement
By cptmike in forum New Holland Owning/OperatingReplies: 11Last Post: 08-16-2012, 03:41 PM -
Voltage Regulator
By matthoffman33 in forum Chinese TractorsReplies: 14Last Post: 10-31-2011, 11:53 PM -
voltage regulator
By mandtandk in forum Chinese TractorsReplies: 12Last Post: 10-30-2006, 07:52 AM -
Ford voltage regulator
By ldp in forum Parts/RepairsReplies: 1Last Post: 10-26-2005, 10:07 AM -
Voltage Regulator
By frank77367 in forum YanmarReplies: 2Last Post: 03-28-2005, 09:50 AM
