Results 11 to 20 of 25
10-02-2012, 08:45 PM #11
Re: Loader bucket wear fix or not?
Don
MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
10-02-2012, 08:47 PM #12
On pic 3, I'm not sure how much play should be there, but the gap seems awfully big.........that holds the top or your bucket to the QA.
It does seem like a lot of clearance doesn't? I would think it would fit tighter, some grease on the adapter once in a while would help a bit on wear.
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
10-02-2012, 10:04 PM #13Bronze Member
- Join Date
- Dec 2011
- Posts
- 50
Before I do this, I have to investigate a bit more.
Just went outside and measured. .225 of an inch (and gotta say, just about yacked, as I was bending over, I inhailed a small bug down wind pipe.....still coughing and waterery eyes,lol)
....this is why I ask, cause it's getting a little to much for my comfort
It does seem like a lot of clearance doesn't? I would think it would fit tighter, some grease on the adapter once in a while would help a bit on wear.[/QUOTE]
it used to fit alot tighter.
......oh ya, lynch pins that's what they are called....lol....I knew that
10-02-2012, 10:42 PM #14Veteran Member
- Join Date
- Jul 2004
- Posts
- 1,553
- Location
- Bancroft, Ontario
- Tractor
- JD4300
I am surprised at how much slop there is under the bucket hooks.Makes me wonder if they got bent somehow, just don't know how you could bend them s long as the bottom lynch pin is in place on the bucket. I have over 4000 hrs on my tractor (JD4300) split between the bucket and a couple of different sets of forks/lifting brackets. Lot of digging and rock work, but only half the slop that you have. I have the steel, rather than the newer cast brackets and mine have bent a bit as well.
I can't see how you could have your bucket come unhooked the way the other style (SkidSteer) does but if you like, you could try to bend those hooks back down with a big hammer. If you fill the space with weld, you might also harden them and make them brittle....
10-02-2012, 11:03 PM #15
Don
10-03-2012, 09:48 PM #16Bronze Member
- Join Date
- Dec 2011
- Posts
- 50
Yes.....brittle...that's what i would think would happen too.
I think what i need to do is go to a JD dealer and get some measurement of the hook and the bar the hook goes over and see from there i guess?
I thank everyone greatly so far in helping me with this issue
Im going to look and or study the whole attachment really good tomorrow since i worked today.
10-03-2012, 10:31 PM #17
Don
10-04-2012, 07:55 PM #18Bronze Member
- Join Date
- Dec 2011
- Posts
- 50
10-04-2012, 08:02 PM #19
Thanks for keeping us informed.
Don
10-08-2012, 10:39 PM #20Bronze Member
- Join Date
- Dec 2011
- Posts
- 50
I will be going to JD Dealer tomorrow morning (Tuesday)....got to buy some dash bulbs....so while I'm there, going to ask and measure new bucket, etc.,
but, will post what I come up with
Similar Threads
How can I fix bucket slop on the loader?
By jobguy in forum Bobcat TractorsReplies: 9Last Post: 07-03-2012, 01:53 AM -
BX23 Bent loader Bucket Howto Fix???
By fierbyrd in forum Kubota Owning/OperatingReplies: 9Last Post: 03-12-2010, 06:08 PM -
Can't fix Leak in my loader Bucket cylinder
By M_Brown in forum HydraulicsReplies: 13Last Post: 11-05-2009, 04:34 PM -
Wear blade for loader bucket ?
By KiotiKevin in forum CustomizationReplies: 2Last Post: 12-09-2005, 05:00 PM -
How to fix Bent holder (loader to bucket bracket)?
By Cdash in forum Parts/RepairsReplies: 4Last Post: 08-31-2004, 07:15 AM
