Results 1 to 2 of 2
  1. #1
    IAM
    IAM is offline
    New Member
    Join Date
    Oct 2012
    Posts
    1
    McAlpin, FL
    New Holland
    Default Source for Ford 22-113 bush hog blade bolt and spacer???
    Where can I find Blade bolts, nut, and spacer for Ford 505 (60") Rotary Mower, Model 22-113??
    Thanks.
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,266
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Default Re: Source for Ford 22-113 bush hog blade bolt and spacer???
    Quote Originally Posted by IAM View Post
    Thanks.
    Any New Holland dealer has or can get those parts.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
Similar Threads
  1. Bush Hog Blade Hardness
    By Chain Bender in forum Build-It Yourself
    Last Post: 01-15-2012, 04:13 PM
  2. bush hog blade bolt removal
    By bruski in forum Parts/Repairs
    Last Post: 06-30-2011, 11:09 AM
  3. Rotary Cutter I need help with bush hog blade
    By mrfrosty in forum Attachments
    Last Post: 05-04-2008, 01:30 PM
  4. Rotary Cutter Bush Hog blade bolt stuck, need ideas
    By Newtogreen in forum Attachments
    Last Post: 06-09-2007, 01:28 PM
  5. King Kutter bush hog shear bolt
    By Mosey in forum Attachments
    Last Post: 04-26-2002, 10:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
