Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    New Member
    Join Date
    Apr 2011
    Posts
    5
    Johnstown, OH
    John Deere 755
    Default Re: Hydraulic cylinder rod reconditioning?
    Thanks, I'll give that a try.
  2. #22
    Silver Member WinterDeere's Avatar
    Join Date
    Sep 2011
    Posts
    149
    Philadelphia
    John Deere 855
    Remove the hoses, and remove the cylinder from the tractor. Have two pans ready, one to sit under the dripping hoses, and the other to dump the fluid from the cylinder into. After removing the snap ring, use the rod itself as a slide hammer, sliding it in and rapidly pulling it out, until it hammers the gland assembly out of the cylinder. Then, put the rod back on the tractor (without the cylinder), so you can remove the nut from the end. That one is a real bugger, torqued at something like 200 ft-lb. with loktite. Be sure you have the right loktite and some spare hose o-rings on hand, before starting this project.
    One thing I never did learn is the right way to purge all the air out of the cylinder on reassembly. I think I'd have been much better off if I had manually filled the cylinder with fluid before reconnecting the hoses, as my bucket action was definitely less responsive after initially doing this rebuild. Maybe too late for me to do that now, as most of the air has probably pushed it's way thru the system.
Similar Threads
  1. Bent hydraulic cylinder rod
    By Mechanos in forum Hydraulics
    Last Post: 07-07-2011, 04:13 PM
  2. 2.5"-3.5" Rod Hydraulic Cylinder-Where to buy?
    By LanceH in forum Hydraulics
    Last Post: 08-08-2010, 08:33 AM
  3. Rotating cylinder rod?
    By jomifo in forum Hydraulics
    Last Post: 09-29-2009, 12:00 PM
  4. Welding on hydraulic cylinder rod eyelet
    By JDeereman in forum Welding
    Last Post: 05-15-2008, 02:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
