Results 1 to 2 of 2
10-11-2012, 07:39 PM #1New Member
- Join Date
- Oct 2012
- Posts
- 1
- Location
- newberry, fl.
- Tractor
- YM2000
Yanmar YM2000 Rear axle seal replacement
My YM2000 started leaking fluid on the left rear wheel outer seal at hub. I found my rear tire was loose
. I took off tire , pulled hub, took off the 4 bolts (5 including safety chain eye bolt) & opened up the outer bearing case . I found my Axle Seal that goes in the outer bearing plate was messed up, but the bearing looked good. I can't find a place to order both the Axle Seal, and the paper 4 bolt gasket to put back together outer bearing cover. Can someone here point me in the right direction?
Thanks, Steve from Fl.
10-11-2012, 07:54 PM #2
Re: Yanmar YM2000 Rear axle seal replacement
Hoye Tractor
Similar Threads
Replacing rear axle seal on Yanmar YM2000
By tmyork in forum New Member IntroductionsReplies: 1Last Post: 09-17-2011, 11:15 AM -
Oil & Fuel L245DT Rear axle oil seal replacement
By South42 in forum Kubota Owning/OperatingReplies: 0Last Post: 06-02-2011, 09:23 PM -
Kubota 245DL rear axle seal replacement
By kindyfarmer in forum Kubota Owning/OperatingReplies: 1Last Post: 06-15-2010, 07:25 PM -
4310 JD rear axle seal replacement
By Kyle_in_Tex in forum Parts/RepairsReplies: 21Last Post: 08-22-2007, 11:25 AM -
Rear Axle Seal Replacement
By NMYAN in forum YanmarReplies: 4Last Post: 04-21-2002, 10:24 PM
