Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    3
    North platte NE
    63/64 Ford 4000
    Default 64 Ford 4000 tractor w problem
    I have a 64 Ford 4000 that I cant keep running. Seems to foul plugs or flood easily and I cant seem to keep it running. Is there something that i may be doing wrong when using it? I've heard these tractors are a bear to start if you flood one. Can someone give me some ideas. I'd really appreciate it.
  2. #2
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,061
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 64 Ford 4000 tractor w problem
    they are a bear to start if they flood, and you don't correct the issue and they continue to flood.. yeah.
    first.
    remove air cleaner line and turn on gas. gas pour out of carb?
    if so.. check float, needle and seat. might be heavy, hung or sticky.. or have trash in the needle.
    machies that overfuel gurgle, and stumble.. smoke.. foul plugs and can stall out.
    check choke flapper to make sure it is not stuck closed.. or stuck and not returning.
    clean those fouled plugs with some spray cleaner like brake or carb cleaner.. then blow out.. fiel or sand, regap.. re clean and blow out and dry... reinstall them.
    make sure air cleaner is serviced and pipe / hose is not restricted.
    check spark.
    weak spark will cause fouling problems.. spark should be snappy and white and jump a full gapped plug.. orange or yellow spark that is weak won't cut it.
    post back some details.
  3. #3
    New Member
    Join Date
    Oct 2012
    Posts
    3
    North platte NE
    63/64 Ford 4000
    I will try that tonite. Thanks for the help. I will post back details soon
  4. #4
    Join Date
    Mar 2002
    Posts
    42,061
    Central florida
    lemme know what ya find
  5. #5
    New Member
    Join Date
    Oct 2012
    Posts
    3
    North platte NE
    63/64 Ford 4000
    It was plugs. Spark was bad. I replaced plugs and it's running great. Thanks for the help
  6. #6
    Join Date
    Mar 2002
    Posts
    42,061
    Central florida
    cool. spark is the first / easiest to chase. I'd rather have spark issues than fuel...
Similar Threads
  1. Insurance Old Ford operator manual ( not shop manual ) for 3000, 4000, 5000 tractor
    By taw50xx in forum New Holland Owning/Operating
    Last Post: 06-25-2012, 08:42 AM
  2. Ford 4000 3 cylinder Tractor
    By awnery in forum Parts/Repairs
    Last Post: 06-18-2012, 01:50 PM
  3. Ford 4000 Electrical Problem
    By JRohrer in forum Parts/Repairs
    Last Post: 05-06-2012, 01:23 AM
  4. 1972 Ford 4000 3-Cyl Gas, Various Problem
    By newtraditionsfarm in forum New Holland Owning/Operating
    Last Post: 04-02-2012, 12:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
