Hello from Ga. I'm new to the forum but I have a mf 35 with a diesel leak where the throttle arm connects. Is this a repair without removing the injector pump? Thanks for any info
If I remember right (I worked on one about 15 years ago) there is cheap (<$30) seal kit for that pump, you can remove the cover and replace the shaft seals. If the shaft is wiggling where it goes through the case, the case needs to be re-bushed. Be very careful about the placement of a shaft and spring (working from my memory) and make sure you put it back in the same spots they were when you took the cover off.
