Results 1 to 2 of 2
10-20-2012, 09:46 PM #1
- Join Date
- Oct 2012
- Posts
- 1
- Location
- Spotsylvania
- Tractor
- 1962 ford industrial
1962 ford industrial tractor
I have a 1962 ford tractor that, once the battery is connected, it wants to crank all the time. I think I have a bad neutral safety switch and don' t know how to replace it.
R
10-20-2012, 10:03 PM #2
- Join Date
- Mar 2002
- Posts
- 52,722
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 1962 ford industrial tractor
post a pic.. does your tractor have a thumb sized button on the trans cover, tht has a lil wire that runs to one o fthe 2 small terminals on the solenoid, with the other one run to the key switch?
if so.. the one from the thumb button is a ground.. and the switch may be bad or the wire chaffed.
pull this wire off the solenoid and see if it still does it.
heck.. the solenoid itself may have it's main contacts welded. if you pull all but the large wires and it still does it.. pop it with a hammer and check agaon.
post back.
ps.. keep her in neutral and clutch blocked during all this testing.
also. is this a sos tractor? they are a tad different than the plain gear models i just described. also possible a prev owner REALLY changed the wireing..
Similar Threads
Ford 532 Industrial Tractor Questions
By Bersaglieri in forum New Holland Owning/OperatingReplies: 4Last Post: 10-08-2013, 12:39 PM -
Ford 545C Industrial Tractor
By lac1957 in forum New Holland Owning/OperatingReplies: 2Last Post: 10-05-2012, 12:37 AM -
Ford Industrial Tractor Identification
By CTPhil in forum New Holland Owning/OperatingReplies: 32Last Post: 11-26-2011, 05:17 PM -
Ford Industrial Tractor Identification, Please Help!
By gravinus in forum Owning/OperatingReplies: 12Last Post: 11-15-2011, 08:02 AM -
Ford 445A industrial tractor anyone??
By GSSFC in forum New Holland Buying/PricingReplies: 6Last Post: 10-26-2009, 06:39 PM
