Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    7
    North Central Florida
    ford 3000
    Default ford 3000 hydraulic problems
    Hi folks, I am new to this site also new to this tractor. I have tried to repair the hydraulic lift with only minor success. it still has a very bad chatter when lifting a heavy implement (box blade 810Lb) have installed lift cover kit, cleaned suction filter, replaced return filter and adjusted per manual,
    control valve and position valve. checked unloader valve.Help!
  2. #2
    Join Date
    Apr 2011
    Posts
    584
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Default Re: ford 3000 hydraulic problems
    Did you replace the O ring a washer on the piston?
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  3. #3
    New Member
    Join Date
    Oct 2012
    Posts
    7
    ford 3000
    yes it was part of the lift cover kit. thanks for the response
  4. #4
    New Member
    Join Date
    Nov 2012
    Posts
    6
    lincoln
    ford 3000, 5000, 6640sle
    I've had to change the oil in my 3000 before and it helped because of moisture. Theres also a draft control lever and a speed control knob which I think acts as a flow control valve to adjust the speed in which the arms raise. sometimes the knob turns but does not actually turn the valve. If your tractor has the aux. valve the problem could be there. It sounds like you have a lack of oil flow.
  5. #5
    New Member
    Join Date
    Oct 2012
    Posts
    7
    ford 3000
    Thanks, I will check it out this weekend it does have the valve.thanks for the info
  6. #6
    New Member
    Join Date
    Nov 2012
    Posts
    17
    upstate ny
    ford 3400
    I am having an identical problem on my ford 3400, which has the same rear hydraulics as the ford 3000 as far as i understand. I just replaced the same things you did, even got the suction filter out and got it completely clean, cleaned out the whole rear end etc.
    I'll list a few ideas, I've already checked these on mine to no avail but maybe they will help you:
    - Draft control knob screwed mostly back in? (You would have had it all the way out if you adjusted cam follower height like me, and it would barely lift deliberately as a result).
    - I read to only use the FNH unloader valve o-ring, as that part is sized critically and cannot be replaced with a standard o-ring. I used the correct part though, and still have this problem. The correct o-ring does not come in the standard lift cover o-ring gasket set so it could trip you up. I don't know exactly what the unloader valve does, so I'm not sure if this would even cause this problem though.
    I'll keep an eye on this thread, please let me know if you find a solution as it might help me with my problem (i'll do the same for you). Currently my lift takes over 20 seconds to raise.
  7. #7
    Platinum Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    989
    Oz
    G'day I have just had a similar problem at work and we tracked it down to the o ring where the suction pipe goes into the pump ( piston pump mounted on the bellhousing), you can check this by squirting a bit of oil round the baqk of the pipe where it goes into the pump and see if this improves your hyd ( the suction is the bigger of the two pipes ).
    Jon
  8. #8
    New Member
    Join Date
    Nov 2012
    Posts
    17
    upstate ny
    ford 3400
    thanks for the idea on the pump o-rings, I may give that test a try tomorrow
  9. #9
    New Member
    Join Date
    Oct 2012
    Posts
    7
    ford 3000
    Checked flow control valve operation this past weekend seems to slow down lift speed but lift still chatters when raising implement, lift also bobs
    when lift is stopped at any height.My tractor has Transmission brake and gear type pump serial # starts with B so must be British model, oil in lift looks like coffee with cream when running must be air in hydraulics, oil looks fine several hours after shut down, has been changed twice with what dealer calls "303" type oil. I am going to try putting oil around suction line at pump today and see what difference it will make . Thanks for all the info.
  10. #10
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    oil that looks emulsified at working, but fine after setting is sucking air and foaming.. i'd deffinately be looking at that external line to the pump
Similar Threads
  1. FORD 3000 problems with restarting
    By mender in forum New Holland Owning/Operating
    Last Post: 10-01-2012, 09:24 AM
  2. Ford 3000???? Problems
    By skitzboy in forum New Holland Owning/Operating
    Last Post: 08-17-2012, 05:58 PM
  3. Ford 3000 Carb Problems
    By Maynor 1 in forum Ford Vintage Tractors
    Last Post: 03-13-2012, 09:40 PM
  4. Ford 3000 Diff Problems
    By Kevin 007 in forum Parts/Repairs
    Last Post: 10-25-2011, 09:04 AM
  5. 1965 Ford 3000 Starter Problems
    By Bharris246 in forum Parts/Repairs
    Last Post: 03-30-2011, 07:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
