Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2011
    Posts
    197
    NW Ohio and SE Michigan
    Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
    Default Ford 4400 Industrial tractor 3cyl gas
    I have a very old Ford (50's ?) with a FEL...the tractor number is C 204620 Model 44021G..Can anyone help with the valve lash or gap?
  2. #2
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,258
    Central Ohio
    Kubota MX5100
    Default Re: Ford 4400 Industrial tractor 3cyl gas
    Definatally not 1950's.
    Thats going to be between 1965 and 1968. No PTO and Gas motor. Transmission code G, 4x4 manual reversing transmission.
    You really need to get a book for it to give the exact specs. And whatever bood you get, will most likely cover your 4500 as well. MANY MANY similarities.
    Also, if you want to know the exact year, there should be a third group of numbers/letters with those you mentioned. C204620 is your serial #, and 44021G is the model #.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #3
    Join Date
    Jul 2011
    Posts
    197
    LD1: Thank You. Only other numbers on the ID plate under the hood are Unit: 8 E 10 B; Transmission: 8 C 19 B; Rear Axle: 7 M 14 B.
    In regards to manuals I found several choices on the internet first beginning with 9.99 for an Ford Operators Manual; 39 mid-range; all the way to 199 for the full 2 volume shop type repair manual from Ford's. What in your opinion would have the basic information I need versus the whole kibbutle?
    This tractor is my right arm for the small garden( 3 acres) I do each year for church kitchens and food banks. The trouble started when I started trying to control Russian Olive Shrubs that were starting to take over the 17acres I have. (check thread I have in the Projects Forum) Not sure what happened but as I was pulling, pushing and tugging the larger ones, the engine started knocking more than usual. I also started getting some underhood smoke which I wasn't sure came from either a loose generator belt or later found that the oil pressure sensor was leaking oil from the side of the block. ( Piece of brush must have pushed against it because the oil dip stick nearby was slightly bent.) My friend (engine repair specialist) and I took off the valve cover and all looked ok except a few of the rockers could be tightened a bit. We we going to drop the oil pan and check for any metal or lead debris but the task looked overwhelming with the need to dismantle the entire block. We did drain the oil to search for debris and felt and magnet probed and again no tell tale debris. We also removed the oil filter and sectioned it and again reasonable clean. Also the oil was not "burned". So at present thought we would tighten the valve lashes to spec and replace the oil sensor and above all hope for the best.
    Thanks Again
    Thanks Again
  4. #4
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,576
    Lincoln County, NC need new avatar!
    Just a Scag
    Quote Originally Posted by docrocky View Post
    Published unit code indicates a final assembly date of May 10, 1968 day shift.
    Spring is the season of optimism.
  5. #5
    Join Date
    Apr 2008
    Posts
    18,258
    Central Ohio
    Kubota MX5100
    Underhood:
    8=1968
    E=May
    10=10th
    B=Dayshift
    Transmission
    8=1968
    C=March
    19=19th
    B=dayshift
    Rear Axle:
    7=1967
    M=December
    14=14th
    B= Dayshift
    As far as a manual goes, the operators manual is about useless IMO. You need something that is actually a shop manual to get the specs.
    I know my manual for my 5500 I believe covers the 4400, and probabally has the specs you are looking for, and I can give them to you if you want. But its going to cost you $10......
    .....Just kidding. I am at work now, and wont be home til about 8 or 9 this evening. If I remember, I can post the specs. But it really is worthwhile to get a manual. One like this Ford 3400 3500 4400 4500 5500 5550 Tractor Manual CD | eBay most likely has what you are after. And that may be the one I have??? I havent opened mine in awhile?
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #6
    Join Date
    Apr 2008
    Posts
    18,258
    Central Ohio
    Kubota MX5100
    Oh, incase you were wondering where all this valuable code-decyphering info is:
    FORD CODES and SERIAL NUMBERS
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #7
    Join Date
    Sep 2000
    Posts
    9,576
    Just a Scag
    The operator's manual is valuable for fluid drain, fill and check points as well as fluid spec's. Periodic adjustments of clutch pedal, brakes and silly things like cold start procedures and control locations and operation are include. The OM is 'useless' only if you have operated this tractor or a similar unit extensively. Otherwise, it contains information that may not be specifically cataloged in a service or parts manual.
  8. #8
    Join Date
    Apr 2008
    Posts
    18,258
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by RickB View Post
    Point taken. I guess if one is new to tractors or new to that particular tractor, then an OM is a good start. I personally just find them usless and full of information that is already pretty obvious for someone who has been around tractors. IE: a full page to show where the oil dipstick and oil fill hole is
    Docrocky: As to the specs, I did find this ford specs. - Yesterday's Tractor Co. Which seems to be about right. Just keep in mind, that lash specs (including those) are almost always with the motor "hot"
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
Similar Threads
  1. FORD 2000 3CYL GAS WONT FIRE
    By CHEEKS in forum New Holland Owning/Operating
    Last Post: 04-28-2015, 05:18 PM
  2. Ford 2000 3cyl gas--Hydraulics
    By ron65729 in forum New Holland Owning/Operating
    Last Post: 07-30-2012, 11:00 AM
  3. Rear PTO on Ford 4400 industrial tractor?
    By kvancott in forum Customization
    Last Post: 12-02-2009, 02:35 PM
  4. Ford 2000 3cyl gas-wont stay running
    By Bullfrog66 in forum Parts/Repairs
    Last Post: 11-05-2004, 01:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
