Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,124
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Ford 3000 Overheat
    let us know how it turns out.
  2. #22
    Member
    Join Date
    Nov 2012
    Posts
    41
    Hale, MI
    Ford 3000
    It appears I have the overheat problem solved. Replaced the carb/intake gasket, new air filter, replaced the vacuum advance line. Verified no apparent air leaks.
    Then took apart the thermostat and found green grass stuck in it pulled it out and cleaned and tested, opened at 185 deg.
    Flushed the system with 2 gals of vinegar and water a little more stuff came out. Filled it with distilled water and ran it.
    Idled over an hour, barely got to the middle of the blue.
    Ended up scraping the driveway and running over three hours continuous and just gets to the top of the blue on the gauge.
    Drained and refilled with coolant and distilled mix, still great.
    Now with that solved I can re-adjust the mixture for the smoothest running/starting.
    Thanks to everyone who assisted.
    John
  3. #23
    Join Date
    Mar 2002
    Posts
    42,124
    Central florida
    glad you got it.
Similar Threads
  1. Buying Advice Ford 3000
    By ArcherXC in forum Buying/Pricing/Comparisons
    Last Post: 11-16-2012, 05:01 PM
  2. Ford 3000 Hydraulic Ford Presure Nut Assembly
    By drof in forum Hydraulics
    Last Post: 11-08-2012, 08:21 PM
  3. Ford 8000 overheat
    By gofarm in forum New Holland Owning/Operating
    Last Post: 10-13-2012, 02:23 PM
  4. Canopy Ford 3000
    By Donovan Caro in forum New Holland Owning/Operating
    Last Post: 04-14-2011, 01:46 PM
  5. FORD 3000
    By fordforlife in forum New Holland Owning/Operating
    Last Post: 01-07-2011, 02:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
