Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Black Mountain,NC
    New Holland TC 40D
    Default New Holland TC 40 D starter wont engage
    Hello, I have a 01 NH TC 40 D that I have had for about 4 yrs, has been great. Have had it stored outside last 6 mo, last started it a month or so ago, never any issues. A couple weeks ago turned the key dash and indicator lights work but nothing at the starter.
    Checked charge it was fine, put on charger while trying to diagnose it for good measure.
    Assumption is a safety switch but have checked all and they are working (brake, neutral, seat, PTO) still nothing.
    Pulled the covers off the below the dash, a bit dirty nothing obvious, so cleaned all debris also pulled all relays / fuse blocks cleaned all terminals and plugs reinstalled with electrical contact grease, still nothing.
    The main fuse on LH side is good,
    Any tips from those of you that know these machines?? I have avoided jumping the solenoid assuming it was a connection or safety switch, but I will do that this afternoon just to get it running. A specific relay for the solenoid I may be missing?
    Ignition switch?? a known problem for others??
    How about tips on a good manual, I have the little 1/4" thick manual from NH that came with it new.
    also tips on good parts suppliers?
    For what it is worth I also have a couple Ferguson tractors at dads old place, a 50 TO20 and a 51 TO30
    Thank you in advance.
    Regards
  2. #2
    Veteran Member Lou66's Avatar
    Join Date
    Nov 2012
    Posts
    1,390
    Brazoria county where Texas began
    Deere 990/Montana 5740
    Default Re: New Holland TC 40 D starter wont engage
    Quote Originally Posted by JerryL View Post
    Regards
    Sound like the contacts in the solenoid,, corrosion,, if so,, easy to fix,, pull the solenoid,, take a part and file the contacts.. hour job on most tractor.. Lou
    "Life is good if beer is cold"
  3. #3
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Black Mountain,NC
    New Holland TC 40D
    Thanks Lou, I found lots of good reading in here since the post. including
    Default Re: TC33D wont start
    Quote Originally Posted by jedjoe
    Wow! This story is remarkable! I'm reading this thread because this morning my tc 35 developed the EXACT SAME symptoms!!!
    On your 35, be sure to look to see if the PTO light is illuminated when the PTO lever is off. If so, you have to replace fuse #2 also. Good luck troubleshooting your problem.
    Jim
    This is what was throwing me off over the weekend, even with the PTO safety switch jumppered the light would not go off, which made me check it in the first place. Will check the fuse in a bit and report back, if that is not it off to test solenoid,
    Great source for info
  4. #4
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Black Mountain,NC
    New Holland TC 40D
    Well is the internet just a wonderful thing!!
    Was fuse #2 as Jim described about 4 pages into a thread.
    What a place for a fuse block, I looked up there a few times as shown in the manual but thought it was not there.
    Well at least all of my connectors have been cleaned and lubed!!
    I would be still interested in what manuals the group uses beyond the small one that comes with the tractor.
    I cant believe the time spent chasing the safety switches, oh well. Off to get some proper fuses then put the covers back on then get some wood up, I am way behind on that. Kind of spoiled using the backhoe and 4 way bucket, the wheelbarrow just does not cut it any more.
    This looks like a very helpful site it is bookmarked and I will be back more often, I use & contribute on a couple on some early cars.
    Thank You!!
    Best Regards
  5. #5
    Gold Member pedalstomper78's Avatar
    Join Date
    Aug 2010
    Posts
    450
    Ohio
    Case/IH DX33
    In that thread mentioned above, the last few pages contain something about putting in a relay between the key switch and the starter. This should help prevent fuse problems and melted key switch problems. I've said this before to people....this is "THE FIX" for the problems with this tractor. This is pretty much a "must do". Spend an afternoon doing it. It's well worth it.
  6. #6
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Black Mountain,NC
    New Holland TC 40D
    I saw some of that yesterday, I did go back and download the wiring diagram and the parts list from the one post, I will look at the diagram and assume a std 4 pin relay should work. I am a big fan of relays to get power where you need it and lighten the load where you dont need or want it.
    Like headlight switches in most early cars, kind of crazy all the amps going through some of those and early ignition switches.
    Thanks again to all contributors. As usual I should have spent more time reading / searching prior to posting.
    Regards
  7. #7
    Join Date
    Aug 2010
    Posts
    450
    Ohio
    Case/IH DX33
    It's no problem. You can search, or you can have people that have searched it 10 times tell you. Either way, I've found that you'll get some guidance. Keep us posted!!!
  8. #8
    Join Date
    Jan 2012
    Posts
    624
    Winchester Ky
    Allis Chalmers ED 40
    I've installed more than one such relay in the cranking circuit on TC series. Not so much for fuse blowing issues, but because the starter can fail to engage at times leading one to suspect battery, post and cable problems. I've learned when this occurs, test the starter by jumping the solenoid start terminal to battery a few times in succession. If the starter engages each time, as it often will, then add the relay.
  9. #9
    New Member
    Join Date
    Sep 2010
    Posts
    4
    Milford, KS
    New Holland TC-29
    i have a 2000 TC29 and I just returned home with it on my trailer and the starter won't engage so I can't unload. I've checked the battery and the fuses and they are all good, any suggestions???
  10. #10
    Veteran Member lhfarm's Avatar
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    I'd suggest using the advance search function and search with the key words TC29 starter. There are millions of posts here and there is a good chance that someone has had this starter issue. Here is one such post -
    http://www.tractorbynet.com/forums/o...d-tc-29-a.html
    Good luck,
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
    '47 Willys Jeep CJ2a w/ PTO
    '49 Willys Jeep CJ3a w/ PTO & 3pt lift
    http://www.farmjeep.com/
Similar Threads
  1. Replies: 7
    Last Post: 05-25-2013, 03:51 PM
  2. New Holland MC28 PTO Wont engage
    By slowgsxr97 in forum Parts/Repairs
    Last Post: 08-01-2012, 07:32 PM
  3. pto wont engage
    By dave1550 in forum New Holland Owning/Operating
    Last Post: 01-05-2012, 06:17 PM
  4. PTO wont engage?
    By hot110ff in forum John Deere Owning/Operating
    Last Post: 05-02-2010, 06:23 PM
  5. PTO wont engage
    By FLJohnDeere420 in forum John Deere Owning/Operating
    Last Post: 07-06-2009, 07:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
