Results 1 to 7 of 7
  1. #1
    cgr
    cgr is offline
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Opelousas, La
    John Deere 5103
    Default 2008 John Deere 5103
    My tractor didnt start last week and found out had no power to injector pump, so i ran a temporary wire to battery positive post and injector pump and it cranked. i disconnected it and traced red wire from pump to key switch and had power at key switch but would not crank. So as to temporary fix problem, i ran a wire from key switch to injector pump and ran fine. Today it will not start and everytime i turn key switch on it blows 30 amp fuse. Any help would be grateful. Thanks.
  2. #2
    Gold Member
    Join Date
    Sep 2010
    Posts
    440
    Virginia
    5210 MFWD
    Default Re: 2008 John Deere 5103
    I believe the problem is the thermistor sensor. On the thermostat housing there is a sensor that is connected to a two wire harness that goes to the injection pump; this is the "cold start advance" portion of the system so it starts easier when cold by advancing the timing.
    When the sensor on the thermostat housing fails it shorts out and blows the fuse. Try unplugging it, replace fuse and see if it starts and runs. The part # is RE503242, if you are quick changing it, you don't have to drain the coolant, just make sure it's not hot at the time. You will want a pan under the tractor to catch the coolant, so as not too have to clean it up.
    You may need to re-prime the fuel system, if it still does not start
    To comply with the exhaust emissions regulation, the timing of injection pump should be around 6 to 9 degrees before TDC. These timing values do not allow proper start-up operations when engine is cold. To ease engine start-up, a cold advance system gives to the injection pump a temporary over-timing.
    When coolant temperature is below 50 C (122 F), the solenoid valve is activated and opens the cold advance circuit.
    URL to JD parts
    jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePa geServlet_Alt
    URL on the 3029 engine and addresses the cold start
    http://www.visaevolution.com/dati_si...5-3029-ENG.pdf
    Attached Thumbnails Attached Thumbnails 2008 John Deere 5103-temperaturesenor.jpg   2008 John Deere 5103-re503242.jpg
  3. #3
    cgr
    cgr is offline
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Opelousas, La
    John Deere 5103
    Thanks JD 5210. I will give it a try and get back hopefully with a smile. Thanks Again.
  4. #4
    cgr
    cgr is offline
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Opelousas, La
    John Deere 5103
    Well i unplugged cold start connection, replaced fuse and its running. It was cold here this morning and it ran rough for a minute and cleared up. Will get new part and change. Thanks again JD5210. This is an awesome forum community. Thanks and God Bless !!!!!
  5. #5
    Gold Member
    Join Date
    Sep 2010
    Posts
    440
    Virginia
    5210 MFWD
    Glad to hear that this fixed your problem and thanks for letting me know. This does appear to be a common problem with the 3029 engines. On the plus side this is the only problem I have seen on various forums with this engine.
  6. #6
    cgr
    cgr is offline
    New Member
    Join Date
    Nov 2012
    Posts
    4
    Opelousas, La
    John Deere 5103
    I went to JD to pick up new part and they said to just leave it unhooked. I was kinda shocked. They assured me it will not hurt anything. They saved me a few bucks.
  7. #7
    New Member
    Join Date
    Feb 2013
    Posts
    1
    upper marlboro, md
    jd 5104
    I have to do the same repair. I have the new thermistor but see that changing is a little tight because there is a line going from the fuel pump to the engine that goes right by
    the sensor. Any advice on whether, you should take off the fuel line first or is it best to try to replace the part without doing this.
    It looks possible not to but very tight.
Similar Threads
  1. john deere 5103???
    By chrisdvorak in forum John Deere Buying/Pricing
    Last Post: 10-17-2009, 08:56 PM
  2. Price Check Used John Deere 5103 Pricing
    By Kingnutin in forum John Deere Buying/Pricing
    Last Post: 04-04-2008, 08:22 AM
  3. Used John Deere 5103 Pricing
    By Kingnutin in forum Buying/Pricing/Comparisons
    Last Post: 04-03-2008, 11:35 PM
  4. 2007 5103 vs 2008 5103
    By mouse2146 in forum John Deere Buying/Pricing
    Last Post: 02-10-2008, 10:01 PM
  5. john deere 5103 or 5203
    By whitearrow in forum John Deere Buying/Pricing
    Last Post: 08-18-2005, 11:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
