Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jul 2012
    Posts
    18
    pickton tx
    kubota mx 5100
    Default shifts fine -won't move
    Hello everyone, this is my first time posting but I have been a member for a while now. Anyway, I recently bought a belarus 400an for $800. I am Familiar with these as I owned one of the same model and when I bought this one I figured I could fix it. It runs like a charm but wont move. The man I bought it from said it was stuck in gear but he realigned the selectors, so it shifted fine but will not move in gear. When I put it in gear it does not do anything - in foward or reverse. I have not hooked up the pto but it turns fine and seems to have strength. I am open to any thoughts. thanks
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Super Member
    Join Date
    Mar 2008
    Posts
    6,627
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: shifts fine -won't move
    Does it have a shuttle to shift between forward and reverse? If so, I would look at that first.
    Sounds like removing the transmission top plate to access the business end of the shift levers may be needed.
    Some pictures of the shifters and the whole operators area would probbaly help.
    Aaron Z
    These questions should not be assessing our students’ ability to decipher convoluted language. Instead, they should be assessing deep understanding of core concepts.
    http://www.washingtonpost.com/blogs/...-tests-failed/
  4. #3
    Administrator
    Join Date
    Jul 2010
    Posts
    2,228
    San Diego, California
    None
    Welcome to TBN
    I moved your thread to the Parts/Repairs forum.
  5. #4
    New Member
    Join Date
    Jul 2012
    Posts
    18
    pickton tx
    kubota mx 5100
    Thanks Briana03 for moving this thread to the right place . My first thread and I’ve already embarrassed myself . Back to what aczlan asked. It does have a shuttle shift but I know thats it’s in gear and I can feel it engage. I also have already taken a look at the "business end" of the shift lever and it looked fine. Personally I’m wondering if its the clutch, it does have 1800 hours on it and it did a lot of loader work (and consequently a lot of shifting). I’m going to do some more investigation later this week but thought it wise to see what everyone at tbn had to say.
  6. #5
    New Member
    Join Date
    Mar 2013
    Posts
    5
    soo,mi
    belarus
    On the bigger, water cooled Belarus, it is easy to get the high/low range stuck into neither. Go make sure the shifter is fully engaging the gear.
    On the air cooled Belarus, there is a pin that has been known to slip out in the rear of the trans that renders you immobile.
Similar Threads
  1. Replies: 6
    Last Post: 09-09-2012, 09:31 PM
  2. bx25 -no longer shifts into 4wd
    By bxn in forum Kubota Owning/Operating
    Last Post: 05-22-2011, 01:22 PM
  3. ct225 shifts hard or not at all
    By unclesalty in forum Bobcat Tractors
    Last Post: 06-18-2009, 05:48 PM
  4. 4wd shifts hard
    By 427stingray in forum Iseki
    Last Post: 10-13-2008, 11:23 PM
  5. HSD Jerks, shifts?
    By Gerald in forum Kubota Owning/Operating
    Last Post: 07-03-2000, 11:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
