Results 11 to 13 of 13
11-26-2012, 06:36 PM #11
Re: 12-point and 6-point sockets
12-point sockets arent appropriate and dont normally work well on square nuts.
Are you thinking of the 8-point type sockets??
And yes, 12-point bolts/nuts do exist, but not something he "average homeowner/tinkerer" is likely to see.
A few examples are Connecting rod bolts or nuts, Flywheel bolts, and sometimes head bolts/studs; just to think of a few common places
".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
11-26-2012, 06:53 PM #12Super Member
- Join Date
- Aug 2001
- Posts
- 8,213
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
As some of the others have said, both serve a purpose but I prefer the 6 point myself. Less chance of damaging a bolt. What is nice with having both is when your bolting something together and need two 1/2" sockets or what ever size for both sides of the bolt. Yeah, you could use a wrench on one side but if there is tension twisting both at the same time sure speeds things up till it cinches down.
When I started expanding my farm operations I soon learned I needed a good set to take to the field for repairs. I ended up buying a set from Home Depot like what you found. Almost 300 pieces of all the sockets you would ever need and an assortment of wrenches, allens and screw drivers. It was a great start. Ended up buying a good metal 3 tray tool box that I could carry it all in. Then I added an 8, 10, 12 and 15" cresent wrench, tape ruler, 1" wide scraper and thread tape to round out that tool box. Then I found I still needed more tools for the "average" field repair so I bought a small black tool box with single tray and have a 3 pound hammer, steel chisels and punches, more thread tape as well as never sieze and tight lock, a small basic socket set (came with the tool box), note pad, pen, pencil, side cutters, linesman pliers, needle nose and pliers. There are a few other items in there as well. I still wasn't happy as I never had the proper wrenches as the original box of tools only had certain sizes. So Home Depot had a couple fo great sets of SAE and Metric wrenches that came in a canvas case that rolls up. They reduced them so I bought 2 of each set. One set stays in the barn just because their handy and the other set stays with my field kits so I have them when ever I need them. Now if I am baling I keep the field tools in the truck at all times. There are very few repairs I can't do with the tools I have on hand. The down side is these kits are set up so nice I find myself going to my field tool boxes I keep stored in the barn before going to the roll chests and using the barn kits
I am always looking for good deals on tools as you can never have enough. Home Depot has Cresent brand adjustable wrenches on sale currently. Have a 6, 8, 10 and 12" all for $20. Just the 12" alone is $20. I try to keep a couple adjustable wrenches on each tractor as well as a 4 in 1 screwdriver and linesman pliers. Can do a lot of field repairs to a tractor with those simple tools. Vineyard tractors have fence pliers instead of linesmans though as well as staples and string in the tool boxes. I bought three of the Cresent kits as I am setting up another roll chest in one of my other barns and I added a couple tractors and needed to put adjustable wrenches in the tool boxes still. I keep looking for another large set of sockets like I originally found as that would be a great jump start on the barn tool box but my Home Depot doesn't stock those kits anymore. Just the small kits.
God must love stupid people; He made so many
11-26-2012, 08:49 PM #13Gold Member
- Join Date
- Nov 2009
- Posts
- 394
- Location
- Beloit, KS
- Tractor
- Kubota B9200 HSTD and Allis 720
I suspect that another reason for the rounded internal corners in the sockets is economy of manufacture. Sharp corners on forging dies tend to wear much quicker than rounded shapes.
Similar Threads
Gripping well point to pull using 3-point lift
By MNBobcat in forum Related TopicsReplies: 3Last Post: 06-19-2011, 09:55 AM -
DF-354 : Hydraulic fluid fill point, drain point, and liquid level?
By mpaschetto in forum Chinese TractorsReplies: 17Last Post: 05-03-2009, 11:22 PM -
Replacing middle buster point with subsoiler point
By queen of spades in forum AttachmentsReplies: 9Last Post: 10-03-2008, 09:26 AM -
3 point backhoe mount changed to 5 point
By hans2 in forum CustomizationReplies: 2Last Post: 10-27-2006, 03:06 PM -
8 point sockets?
By DEERSLAYER in forum Related TopicsReplies: 2Last Post: 08-30-2006, 06:50 PM
