Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    6
    Greenwood SC
    1972 ford 3000 diesel
    Default 1973 Ford 3000 diesel rear axle seal replacement
    Could any one tell how much trouble it is to pull the rear axles and replace the seals in a ford 3000 diesel ,,and do i need to replace the inner seals as well as the outer seals ,,,there leaking pretty bad .(NO BRAKES) Thanks Randy
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,537
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 1973 Ford 3000 diesel rear axle seal replacement
    The outer seal is more difficult to replace than the inner. Both should be done to ensure an effective repair. Removing the bearing retainer (either a shrink collar or nut, depending on whether you have differential lock or not) and outer bearing is the most challenging part of the job. Many owners remove the axle shaft and bearing housing as a unit and take them to a dealership or repair shop familiar with the job and equipped to do it.
    Spring is the season of optimism.
  3. #3
    New Member
    Join Date
    Mar 2012
    Posts
    6
    Greenwood SC
    Thanks for the info RickB just trying to gather info before i start this job ,,its my tractor and it does not have a differintial lock TKS again. Randy
  4. #4
    New Member
    Join Date
    Mar 2012
    Posts
    6
    Greenwood SC
    ok ,im back thanks for the previous help ,,,i now have both axles out and on my work bench ,there was no play or movement on the rear axle after i removed the wheels... bearings seem to be fine,but there was not much grease around the bearings but they have been in for 38 years,so im thinking of driving the nut off with chisel and hammer and reuse the nut with some very strong lock tite ,so if i do get the nut off and pull the axle apart from the outer housing will i then be able to replace the outer seal with out any more parts such as bearing race TKS for your help
Similar Threads
  1. Yanmar YM2000 Rear axle seal replacement
    By spo in forum Parts/Repairs
    Last Post: 10-11-2012, 07:54 PM
  2. 1973 Ford 3000 diesel
    By mojo0768 in forum Parts/Repairs
    Last Post: 07-12-2012, 04:33 PM
  3. Ford 3000 rear axle seal
    By cotemart in forum New Holland Owning/Operating
    Last Post: 11-01-2010, 07:40 PM
  4. 4310 JD rear axle seal replacement
    By Kyle_in_Tex in forum Parts/Repairs
    Last Post: 08-22-2007, 11:25 AM
  5. Rear Axle Seal Replacement
    By NMYAN in forum Yanmar
    Last Post: 04-21-2002, 10:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
