Results 11 to 20 of 24
11-29-2012, 08:04 AM #11Elite Member
- Join Date
- Feb 2011
- Posts
- 3,428
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
Re: To Bleed or Not To Bleed ???
::"I STARTED out with nothing....I still have most of it."
New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
11-29-2012, 08:29 AM #12Super Member
- Join Date
- Sep 2000
- Posts
- 6,358
Any air in the line is pumped to the cylinder and while the seals hold the fluid, they allow air to pass into the return line. The return line goes to the reservoir - not the pump. The reservoir is vented so the air will get out - thus the system is not totally closed. Every time you extend a cylinder the reservoir breaths in that volume of air and every time you retract it exhales that amount. The vented filter cap is "ok" but it does let in some dirt and water from the air. That's why you need to change the fluid every so many hours to get that contamination out.
After installing new line or cylinder, etc fully extend then retract the cylinder. Stop the machine, wait a few minutes for the bubbles to all go away then check the fluid level. Simple as pie!
11-29-2012, 08:44 AM #13Elite Member
- Join Date
- Feb 2011
- Posts
- 3,428
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
11-29-2012, 09:13 AM #14
Are you saying you have a single acting cylinder that you are working on? Most tractors or implements have double acting cylinders so there is a "return" line. Hydraulics on a tractor is really a open system. In your case - getting fluid through the hose first and then hook up to the SA with it retracted should take care of most of your paranoia. Any air left will work itself out.
I can see where you might be confused. In a vehicle there is a bleeder because fluid is supposed to go one way in the system. On a tractor, it can go back and forth to the reservoir. When fluid can go back and forth- it can push that bubble of air back to the tank where it can go free. on a car - it has no place to go but through the bleeder screw.
11-29-2012, 09:29 AM #15Elite Member
- Join Date
- Feb 2011
- Posts
- 3,428
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
11-29-2012, 09:51 AM #16
Are you having certain problems with your hydraulics? It sounds like you are trying to solve something and hung up on how the circulation works. Unless you have a very unique / like no one has seen before system, the fluid does flow or should flow how it has been described. Tell us what problem you're experiencing so we can help solve that.
Originally Posted by crash325
Gary
JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
11-29-2012, 09:59 AM #17Elite Member
- Join Date
- Feb 2011
- Posts
- 3,428
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
11-29-2012, 12:22 PM #18Super Member
- Join Date
- Sep 2000
- Posts
- 6,358
No disrespect, but you may have a distorted understanding of what you are looking at.
The "cylinder fluid return" is part of the control valve. When you upset the valve (move it to cause the cylinder to move) pressurized fluid goes down one hose to the cylinder causing it to extend or retract, and the other hose FROM the cylinder has it's fluid directed by the valve out to the tank return. There are variations around that theme, but in general all hydraulic systems work that way.Last edited by john_bud; 11-29-2012 at 01:04 PM.
11-30-2012, 01:22 AM #19Super Member
- Join Date
- Aug 2006
- Posts
- 5,107
- Location
- Front Range of Colorado
- Tractor
- JD 4200 C.U.T. & JD 130L Lawn tractor
Assuming your hoe is powered via a Power-Beyond set of connectors on the tractor, one PB line is pressure out to the implement's control valve that directs the oil to various cylinders and back again depending on the control lever(s) position, and the other PB line is return to sump from the implement's control valve. What you are describing would deadhead the pump since the oil is not in constant circulation and the pump would eventually get unhappy from deadheading the fluid.
If for some reason your hoe has an independent hydraulic system powered by the tractor's PTO or a gas engine, you would still have a sump on the hoe for the oil to return to. Whatever air that is in the system goes back to the sump to vent to atmosphere.My 24/7/365 menu for GITMO: Bacon for breakfast, a ham sandwich for lunch, and a pork chop for dinner.
Stuff I've made for the JD4200 or done with it are at this link. http://picasaweb.google.com/mjncad
11-30-2012, 01:05 PM #20Platinum Member
- Join Date
- May 2005
- Posts
- 942
- Location
- Eastern MA & Upstate NY
- Tractor
- John Deere 770, Bobcat 753
Crash,
(Nice name BTW) The two lines on the cylinder act as both pressure and return, depending on the action requested by the operator. So while extending, the bottom port receives pressure from the valve body, the top port then returns fluid to the valve body, which then returns it to the vented sump. Reverse fluid flow to retract piston. The valve body receives pressure and has a non- pressure return to sump at all times.
So there are no dedicated low pressure return lines anywhere on a backhoe other than the one from the valve body to the sump. All pressure lines have a secondary function as returns.“I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
Similar Threads
To Bleed or Not to Bleed.....
By beersngars in forum Kubota Owning/OperatingReplies: 10Last Post: 10-13-2009, 02:54 PM -
what does a bleed value look like
By millpond in forum HydraulicsReplies: 4Last Post: 07-05-2007, 12:42 PM -
bleed green to bleed orange
By mikeyd in forum Kubota Owning/OperatingReplies: 11Last Post: 06-04-2007, 07:52 PM -
How much do you really bleed???
By thcri in forum Related TopicsReplies: 19Last Post: 04-30-2007, 09:12 AM -
By thcri in forum Buying/Pricing/ComparisonsReplies: 9Last Post: 04-29-2007, 01:13 AM
