Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,442
    Tucson AZ
    New Holland TC-45
    Default Re: To Bleed or Not To Bleed ???
    I sure hate it when I'm wrong.
    You folks were right all along. It's all working now. line re routed, everything back together. Need to split some old water hose & clamp it on the rub points & I be done.
    Thank all of you.
    ::"I STARTED out with nothing....I still have most of it."
    New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
    All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
  2. #22
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,092
    Westminster, MD
    John Deere 4110
    Good news Crash
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  3. #23
    New Member
    Join Date
    Oct 2012
    Posts
    17
    Fenton, Mi
    Kubota L2550GST(4wd), Mitsubhish MT160D (4wd)
    Awesome thread everyone. As a city guy moved to the county w/ a Kubota tractor, backhoe, loder package I just replaced my first hose on the backhoe. Made me think of my 69 Olds 455 w/ 4 wheel standard shoe brakes. and I became very adept and bleeding. I was about to go make a mess and I think I know just to connect and go! Thanks everyone for a awesome forum! I could not fix the stuff I have with out you.
    JJ Countryguy (I keep trying anyway).
    Ohhh- And my wife is the same- classic city girl. So she became a bit distrssed when I started grabing uncut fire wood sections to prop and jackstand a dissasemmbled Backhoe. I told here Welcome to farming mechanics & repair 101. She game me that look guys. :-) anyway, She is now quite happy w/ the $500 we saved from the dealer repair est. Love it!~ going to dig by Dinner time. GB And stay safe.
  4. #24
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    Front Range of Colorado
    JD 4200 C.U.T. & JD 130L Lawn tractor
    The big difference between a tractor's self-bleeding hydraulic system and a car's non-self-bleeding brakes is that on a tractor the hydraulic fluid is constantly in motion, and the return fluid (oil & trapped air) dumps into a large sump where the air can escape from the oil.
    On a car, the air bubble is trapped between the master-cylinder and the brake-cylinders in a system that sees very little fluid movement. When you press on the brake pedal, the fluid and the bubble are being forced away from the master-cylinder reservoir; therefore the bubble doesn't have an opportunity to float to the top and escape into the reservoir.
Similar Threads
  1. To Bleed or Not to Bleed.....
    By beersngars in forum Kubota Owning/Operating
    Last Post: 10-13-2009, 02:54 PM
  2. what does a bleed value look like
    By millpond in forum Hydraulics
    Last Post: 07-05-2007, 12:42 PM
  3. bleed green to bleed orange
    By mikeyd in forum Kubota Owning/Operating
    Last Post: 06-04-2007, 07:52 PM
  4. How much do you really bleed???
    By thcri in forum Related Topics
    Last Post: 04-30-2007, 09:12 AM
  5. How much do you really bleed???
    By thcri in forum Buying/Pricing/Comparisons
    Last Post: 04-29-2007, 01:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
