Page 5 of 5 FirstFirst ... 2345
Results 41 to 42 of 42
  1. #41
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    3,781
    SW Pa.
    Massey Ferguson GC2400
    Default Re: Parasitic load on battery
    Quote Originally Posted by joshuabardwell View Post
    Sorry. I wasn't being sarcastic. I was sincere.
    Right. The head-smacker was that I hadn't thought to remove the battery and just take it in to be tested.
    No worries my friend. Hope you find the problem soon.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  2. #42
    Join Date
    Jul 2004
    Posts
    1,553
    Bancroft, Ontario
    JD4300
    I'm thinking much the same as Rangerrzr, a battery that has an electrically "dirty" top. The way you test by lifting the ground will show a current flow. Have you ever tried the same test by lifting the pos lead instead and did you get the same reading? You can also test by taking voltage readings from one post to various places on the battery top. While the pos lead is off, clean up the lead until it is bright and shiney, both on the battery post and the cable end.
    Around here I often find that corrosion has built up just enough to prevent the battery from taking a full charge and the problem always seems to come to light in the fall when it gets cold.Something about the foggy mornings....
Similar Threads
  1. Parasitic drag of hydraulic motor question
    By ParkerFly in forum Hydraulics
    Last Post: 09-18-2011, 10:15 PM
  2. Load in Truck vs Load on Trailer
    By Harold_J in forum Trailers & Transportation
    Last Post: 01-13-2011, 03:56 PM
  3. BX23 parasitic battery drain
    By Tollster in forum Kubota Owning/Operating
    Last Post: 11-06-2007, 10:00 PM
  4. To Load or Not to Load (FEL question)
    By mstewart44 in forum John Deere Buying/Pricing
    Last Post: 09-11-2007, 09:51 PM
  5. 3015 tires--to load or not to load
    By pk1mk1 in forum Mahindra Owning/Operating
    Last Post: 07-28-2006, 12:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
