Results 11 to 20 of 22
12-02-2012, 12:18 AM #11
Re: Anyone know anything about 12 Volt DC motors?
It is likely you alligator clips are probably smaller than 16 ga. and if you do get it going your clips are going up in flame.. 10.5 amps ia quite a bit. and you wireing and connections need to be able to supply this as well as having a good battery. Of course as others have said, there is no way to turn the shafts by hand. These motors are little powerhouses, with 60 ft. pounds of torque.
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
12-02-2012, 12:58 AM #12Elite Member
- Join Date
- Dec 2007
- Posts
- 3,514
- Location
- Ohio
- Tractor
- JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
It's 60 inch lbs of torque, not 60 ft lbs. It just dispenses fertilizer.
Even if I had light allegator clips and wire, wouldn't I get some sort of bump out of the motor?******
Don't sweat the small stuff...
12-02-2012, 07:48 AM #13Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,660
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
With a motor that draws 10.5 Amp running you should get quite a spark at the battery terminals when you connect. The initial inrush currant will be much higher. Your 12 Ga wire is fine but you may have burnt the clipleads. If your battery is really OK then you have an open circuit somewhere. Either your wiring or in the motor.
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
12-02-2012, 07:53 PM #14Bronze Member
- Join Date
- Nov 2012
- Posts
- 88
- Location
- Newark, de
- Tractor
- International 424
Are they Bi directional motors? Ground the motor and one of the alligator clips on Positive would run it in one direction, then reverse direction with the other?
12-02-2012, 08:17 PM #15Platinum Member
- Join Date
- Oct 2011
- Posts
- 720
- Location
- NJ
- Tractor
- Ford 2600, NH TC-25, Bobcat M610, JD X534, DigIt Model 158
Look here for some specs on the motor.
Look up the frame number, 74-jk-0,fromthere you will find the rest. There's not a lot in there, just a simplemconnection diagram and some mounting dimensions.
http://www.baldor.com/pdf/brochures/ca1500.pdf
12-18-2012, 03:03 AM #16Elite Member
- Join Date
- Dec 2007
- Posts
- 3,514
- Location
- Ohio
- Tractor
Here's how this ended. I took the motors to a shop that checked them out and cleaned them. They said they were like new inside but dirty. They now work like they should and my plan is to sell one of the fertilizer units and motors to help pay for the cost of the other one. This sounds dumb but I think these motors and gear reducers retail for $770. How can they possibly cost this much? I mean, they are beautifully made but $770?
Products: Gear Products: GP7401: Baldor Electric Company, a leader in energy efficient electric motors, linear motors and adjustable speed drives industry
Anyway, cost was minimal and while I admire greatly those of you that can diagnose these kinds of things with multi meters, that science and art form escapes me and the shop worked for me.******
12-18-2012, 06:59 AM #17Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,660
- Location
- NorthEastern, VT
- Tractor
Thats great
Thanks for getting back to us.
I take it from what you said that the brushes and commutators were dirty ?
Or was it something else ?"If you're not making any mistakes then you're not doing anything"
12-18-2012, 08:56 AM #18Elite Member
- Join Date
- Dec 2007
- Posts
- 3,514
- Location
- Ohio
- Tractor
Guy said things were dirty and he just cleaned things up and put it back together. I presume something simple like dirty surface where the brushes ride. Funny, but I used to do this work in a garage 45 years ago but have since forgotten whatever I knew.
It's a great shop with very thorough people so I just said thanks, tipped my hat and paid the lady at the window. He said it was a real quality motor and gear reduction and a pleasure to work on. Can these motors with gear reducers really cost what I think they cost?******
12-18-2012, 09:13 AM #19Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I think it would be hard to sell a fertilizer distributor if the motor cost $700 or even 200 unless it was to NASA for fertilizing the moon. Public money is easy to spend but individuals to put out $1000 for a fertilizer would have to have just fallen off the turnip truck
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
12-18-2012, 09:35 AM #20Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
i bet the comie was dirty...
Similar Threads
JD 820 - 6 volt alternator on a 12 volt tractor?
By glenhenshaw in forum John Deere Owning/OperatingReplies: 35Last Post: 10-05-2011, 08:31 AM -
12 Volt/24 Volt Battery Booster Box
By penokee in forum Parts/RepairsReplies: 8Last Post: 06-30-2011, 12:31 PM -
6 Volt Gator, 12 volt TSC spray pump ?
By bcarwell in forum Parts/RepairsReplies: 17Last Post: 11-09-2010, 01:53 PM -
12 Volt-110 Volt Power Inverters
By SkyPup in forum AttachmentsReplies: 16Last Post: 05-21-2005, 04:22 PM -
Switch Ford 640 to 12 volt? (6 volt now)
By tillboy2001 in forum Ford Vintage TractorsReplies: 10Last Post: 03-31-2005, 02:02 PM
