Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    2
    Winnipeg MB
    Kioti CK30
    Default Kioti Tractor will not turn Over - Just CLicks
    Changed the battery in my 2007 CK30 Kioti tractor. It will now only click, so I changed the terminals. Just clicked. Tried jumping it and nothing. There is a relay that is connected to the preheater that was vibrating. Any ideas what this issue can be?
  2. #2
    Super Member murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    6,427
    Ohio
    Kioti DK 40-Massey ferguson 135-Simplicity Conquest
    Default Re: Kioti Tractor will not turn Over - Just CLicks
    Well, I've been reading of a lot of ignition switches being changed on your model and year.
    Murph ------------ Sent from my HP laptop
    Nothing runs like a Deere when being chased by a Kioti
  3. #3
    New Member
    Join Date
    Dec 2012
    Posts
    2
    Winnipeg MB
    Kioti CK30
    And that was the symptom they were having?
  4. #4
    Join Date
    Jan 2012
    Posts
    752
    Ma
    Kubota b2920
    That also is the symptom for a battery without enough power to turn over the engine. Have you tried verifying the new battery is charged? I've noticed if I jump my tractor that it's very difficult and that I need to let the battery charge for a few minutes before I get any progress, otherwise it just clicks. That's where I'd start since its a simple explanation...
  5. #5
    Elite Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    4,104
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by Richie204 View Post
    Yeah, the starter switch is a common problem, esp if you let water get into it.
    But more common is a bad ground connection. You said you changed the terminals.
    Did you change the whole wire and clean off the frame connection?
    See my TBN projects at:
    http://mysite.verizon.net/resyfcgt/
  6. #6
    Veteran Member Gittyup's Avatar
    Join Date
    Oct 2007
    Posts
    2,411
    Mid Atlantic
    Kioti CK25 Shuttle Shift, loaded tires
    if you changed the battery, and have good connections, it's probably a relay. Search in the Kioti forum. Others have had relays problems. Obviously power is not getting to the starter; check the wiring diagram. With an ignition switch failure, I'm not sure you'd even get a click at any of the relays.
  7. #7
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    It sounds like low voltage. I'd put a 200 amp jump starter on it and see if that makes it spin.
    If that doesn't, I'd look at the ground side and maybe even the simple stuff like the cables to the starter, then solenoids switches etc.
  8. #8
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,808
    NOT HERE
    Have you checked the battery, how many volts does it have? Are the cables tight at the battery and starter? Is there are corrosion on the cables? Did you clean the battery terminals off when you put the new one in? They have oil on them when they are new. If all of that is good how many volts do you have at the starter?
  9. #9
    Gold Member pedalstomper78's Avatar
    Join Date
    Aug 2010
    Posts
    361
    Ohio
    Case/IH DX33
    Need to start with something else.....did it do this before you replaced the battery also? If so, there's a chance that there's a starter solenoid problem.
  10. #10
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,074
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    charge bat, clean all terminals and posts, including ground. if ground is sheet metal, and not chassis.. clean the connection betweenthe 2.
    post back
Similar Threads
  1. JD 750 tractor clicks, tries to turn, won't start
    By stamello in forum Owning/Operating
    Last Post: 01-29-2013, 10:52 PM
  2. My New Holland TC- 29 won't start...clicks.only
    By brin in forum Owning/Operating
    Last Post: 11-14-2012, 09:47 PM
  3. 2210 won't start just clicks
    By dog5farm in forum John Deere Owning/Operating
    Last Post: 07-23-2012, 09:05 AM
  4. 2166 new battery, just clicks.
    By Andrewra in forum Cub Cadet L&G
    Last Post: 07-06-2011, 06:20 PM
  5. BX23 clicks
    By mscott in forum Kubota Owning/Operating
    Last Post: 10-25-2009, 08:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
