Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    2
    louisville, ky
    1405 cub cadet
    Default 1405 cub cadet transaxle slipping in 2nd and 3rd gear
    I have replaced the shifting keys and all gears look good. I found nothing wrong in the transaxle except the shift keys. I went through all the gears and all in correct in the transaxle per the manual. The mower will pull a few feet in 2nd or 3rd then start slipping. I have also replaced the sheave on the engine drive and replaced the drive belt. I adjusted the belt as tight as possible for it to operate correctly. I have no problem with slipping in 1st, 4the and 5th gear. I would think I am overlooking something in the transaxle. I need help.
  2. #2
    Member
    Join Date
    Nov 2012
    Posts
    48
    Parrottsville TN
    Kubota
    Default Re: 1405 cub cadet transaxle slipping in 2nd and 3rd gear
    Join OnlyCubCadets.com
    They can help you.
  3. #3
    New Member
    Join Date
    Dec 2012
    Posts
    2
    louisville, ky
    1405 cub cadet
    Thanks for your suggestion. I will look into that sight. But, do you have any idea what my problem by be?
  4. #4
    Member
    Join Date
    Nov 2012
    Posts
    48
    Parrottsville TN
    Kubota
    I've only owned and worked on the big ones.......they'll help you there.
  5. #5
    New Member
    Join Date
    Dec 2012
    Posts
    10
    Orange mass
    Johndeere 2012
    Valve body needs to be clean the valve body springs and bearings on top of the springs that close off ports are dirty and allowing fluid to blow by bearing creating leak on pressure side causing slippage !
Similar Threads
  1. Cub cadet 129 hydro tranny slipping
    By ptplumer in forum Cub Cadet L&G
    Last Post: 05-07-2010, 10:27 PM
  2. slipping out of 2nd gear
    By Jim2 in forum Yanmar
    Last Post: 08-28-2009, 09:54 AM
  3. cub cadet creeper gear
    By joes_427_vette in forum Cub Cadet Yanmar & CUTs
    Last Post: 07-28-2006, 09:47 AM
  4. hydro-gear transaxle for 1720 cub cadet
    By steve358 in forum Cub Cadet Yanmar & CUTs
    Last Post: 10-04-2005, 06:39 PM
  5. clutch slipping - Cub Cadet 2135
    By rayJandreau in forum Cub Cadet Yanmar & CUTs
    Last Post: 05-25-2005, 07:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
