alexmt
Metering valve in the pumpcover stuck in the shutoff position.
Did the engine ref up a little and the die ? Water in the pump ? Open the window and catch all the fuel coming out and check for water !
thanks so much for you help i took off the pump and open up the top and discover that the stop lever was not returning to position by its self. I filled the pump with transmission oil and worked the stop lever back and forth and now it is working. I hope thats the solution to my problem thanks for your time to reply to my problem take care
