Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    3
    auburn ca
    1020 diesel 4wd-1936 RD4 CATTERPILLER-1948 FARMALL CUB
    Default 1020 hydraulics
    got a1020 it had sit for a while, fired it up and no hydraulics! so added some fluid and still nothing loader or rear.
    is it possible there is air in the lines or pump Thanks for your support Bill
  2. #2
    Gold Member tthopskin@yahoo.ca's Avatar
    Join Date
    Dec 2009
    Posts
    310
    madoc ont 30 t years
    and i just got a 580 c case backhoe real good shape got another kubota 2100 .. 2 - 684 IH 2 -8 N Ford had B275 IH MF # 50 work bull MF 35 all redone 65 mf 1750 kabota
    Default Re: 1020 hydraulics
    from sitting a relief valve maybe stuck open try it 2-3 times a day it mite shut and your good to go ..some of the older tractors had a ball on a spring and it would stick open and shut down the hydraulics .. good luck
    JACK OF ALL TRADES MASTER OF NONE
  3. #3
    New Member
    Join Date
    Dec 2012
    Posts
    3
    auburn ca
    Thanks for the input,where would the relief valve be on the 1020?
  4. #4
    Join Date
    Dec 2009
    Posts
    310
    that i dont know ...every tractor has them in different spots .good luck
  5. #5
    New Member
    Join Date
    Mar 2013
    Posts
    2
    Thomasville NC
    MF 1020
    Quote Originally Posted by tthopskin@yahoo.ca View Post
    Did you get it working? I have the same problem
  6. #6
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Check to see if the pump is pumping fluid.
    The pump may need primed.
    Have you checked and replaced the hyd filters and cleaned the screen if it has one.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
Similar Threads
  1. mf 1020
    By haroldy in forum Massey Ferguson Owning/Operating
    Last Post: 03-15-2011, 08:47 PM
  2. JD 1020
    By deerman2 in forum Parts/Repairs
    Last Post: 05-16-2010, 01:59 PM
  3. Loader MF 1020
    By Hoby Farmer in forum Massey Ferguson Owning/Operating
    Last Post: 04-24-2010, 12:42 PM
  4. MF 1020 Hydraulics no go
    By Van Wen in forum Hydraulics
    Last Post: 03-29-2009, 07:00 PM
  5. 1965 JD 1020 Hydraulics disappeared. Need advice.
    By ME Gentleman Farmer in forum Hydraulics
    Last Post: 02-08-2009, 11:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
