kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,910
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
Bought a used KKII rototiller back during the summer and the PTO shaft works fine until I lift it, whereby sometimes the two PTO shaft sections will come apart. Obviously it was sized for the tractor that it was originally on. I would like to see if I can locate another "tractor end" section like in the pictures, that is longer, so I can cut it down. I think if it had just about 2-3 inches of add'l length, it would do just fine. I know some will suggest to just buy a complete new shaft and start over. They are only $219 at TSC with the slip clutch, and the one I have is basically new, so I want to avoid that route! This is a pretty short PTO shaft setup, I think if I can get just a couple more inches of overlap with one section, it will be just fine. If it were a really long PTO shaft like on a BH or PHD, then I would agree it would probably be best to get a new one and start over. Any thoughts on where I can get new or used section at a reasonable price? It's the standard 1 3/8" six spline on the tractor end, and the other end is tri-tube. Not sure of it's dim's though.
