Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    1
    ottawa, ontario
    384 IH
    Default 384 IH rolls over but won't start...
    384 IH diesel...it started fine and I let it warm up for about ten minutes. I put it in gear and it went about ten feet, and died. I had used it the day before for about 3 hours without any problems, so I don't think its the fuel. Not even getting a puff of smoke out of it. The injector pump and one of the injectors is wet with fuel, however I don't know if this is fresh or something I just hadn't noticed. Not familiar with deisel engines so any help or suggestions would be appreciated. Thanks.
  2. #2
    Join Date
    Dec 2011
    Posts
    226
    Default Re: 384 IH rolls over but won't start...
    The CAV DPA pump on these machines need a good flow of fuel, far more than just for injection the problem will probably be a blocked fuel system, a diesel needs a lot more fuel flowing through the system than that required for fuelling the motor, check the fuel lines and fuel tap, change the fuel filter.Also inspect all lines, hoses and joints for any air ingress which can stop the engine from running.
    As its a CAV rotary pump and you have checked all of the above, the bleeding sequence is quite important 1/ bleed the fuel through the filter, then 2/ through the 'top' pump bleed screw, then 3/ the bleed screw on the pump body, then 4/ the pipes at the injectors, start the tractor and 5/ back off the pump body bleed screw for 5 seconds or so to ensure that all the air is bled, otherwise the tractor will refuse to start next time!
Similar Threads
  1. IH 384 weight
    By DKL in forum Case-IH
    Last Post: 08-26-2012, 08:04 AM
  2. IH 384 age
    By Brakeman in forum Case-IH
    Last Post: 09-15-2011, 08:53 PM
  3. 384 IH won't start?
    By scooter001 in forum Case-IH
    Last Post: 06-12-2011, 11:34 AM
  4. B3030 rolls away
    By jusdande in forum Kubota Owning/Operating
    Last Post: 12-30-2007, 05:18 PM
  5. international 384
    By ljw in forum Case-IH
    Last Post: 06-14-2000, 06:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
