Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Join Date
    Dec 2012
    Posts
    161
    jackson michigan
    oliver 1855 Diesel, Bobcat 863F skidsteer, john deere 855
    Default Re: Painting an Oliver 1855
    The rattle cans I picked up from my local AGCO were branded AGCO and was produced by Valspar. It is an enamel for machineary. Am I taking a chance on using this?
  2. #12
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,559
    Texas
    In 1956 my Dad bought a Mobil service station and the Mobil distributor also had a farm. I don't remember what model his Oliver was, but I do remember that was the first time I'd seen a tractor that had two reverse grears. Sure was a great tractor.
    Bird
  3. #13
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    When I purchased mine, the day my dealer delivered it, the driver backed off the truck and that chain fell off, he winched it on and took it back, I got it the next day. The only real problem I have had it hydralicfluid leaking into rear end, Its the PTO,I had to disconnect the two 1/4" lines and bypass it.
    I have not tried Valspar paint, but Vansickle is junk. Yes 2 reverse and over/direct/under drive, this works great for moving snow in large parking lots.
  4. #14
    Join Date
    Dec 2012
    Posts
    161
    jackson michigan
    I agree Dr Dave. The Over Under works great and will come in very handy. I like that I can shift on the fly between Under, Direct and Overdrive. I am sorting out several small leaks. Nothing bad enough that you can find puddled or even show on the ground under the tractor but a mist of oil on or around the PTO shaft area, the oil line to the oil pressure gauge and I think a little fuel leak under the tank. Again none are enough that you find spots or a puddle under the tractor but I will be checking O rings and gaskets for the next few weeks to dry everything up.
  5. #15
    Join Date
    Mar 2000
    Posts
    40,559
    Texas
    Never worked on a tractor in the snow but it was sure handy when cutting/baling hay.
    Bird
  6. #16
    Join Date
    Dec 2012
    Posts
    161
    jackson michigan
    I will be finding this out come spring. I have 30 acres I am putting into grass hay for our horses. Plan on using my 1855 and my brother in laws attachments. I have a chisel plow that came with the tractor but my brother in law, the farmer, threatened me if I used in on the soon to be hay field. He says I will bring up so many rocks I would not believe it. The field had soy beans in it the last two years and corn the pervious 4 years. My wife and I have 5 horses and this year we are going to put up our own hay.
Similar Threads
  1. Oliver 1855 diesel oil pressure problem
    By Oliver1855 in forum Parts/Repairs
    Last Post: 01-04-2013, 11:37 AM
  2. Replies: 12
    Last Post: 01-02-2013, 02:17 PM
  3. 1855 cockshutt
    By tthopskin@yahoo.ca in forum Owning/Operating
    Last Post: 01-02-2013, 10:33 AM
  4. fuel filter conversion on oliver 1855
    By jerry shannon in forum Customization
    Last Post: 12-24-2012, 01:08 PM
  5. 1855
    By C Holmes in forum Massey Ferguson Owning/Operating
    Last Post: 09-04-2006, 03:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
