Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,935
    Pennsylvania
    Kubota BX25
    Default Need Help Replacing Work Light Bulb
    I need your help! I have a magnetic 12volt worklight I purchased at TSC. A few months after I bought it, it stopped working. I took it apart, and I found that the filament in the bulb was broken. Now I can't get the bulb out to find a replacement. I tried and tried, but it would not budge. I was wondering if anyone on here knows a way to get it out? I would really hate to toss the whole $20+ light just because the bulb is broken.
    Of course, attached are some pics:
    Need Help Replacing Work Light Bulb-p1020896.jpgNeed Help Replacing Work Light Bulb-p1020898.jpgNeed Help Replacing Work Light Bulb-p1020901.jpgNeed Help Replacing Work Light Bulb-p1020904.jpgNeed Help Replacing Work Light Bulb-p1020907.jpgNeed Help Replacing Work Light Bulb-p1020909.jpgNeed Help Replacing Work Light Bulb-p1020912.jpg
    Thank for any advice you can provide.
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  2. #2
    Join Date
    Jan 2006
    Posts
    164
    Default Re: Need Help Replacing Work Light Bulb
    Is this the unit you have?
    Blazer Heavy Duty Magnetic Work Light - 0283852 | Tractor Supply Company
    If so, the bulb is listed as H3-55W Halogen Bulb.
  3. #3
    Gold Member
    Join Date
    Oct 2010
    Posts
    322
    08 Cub Ex3200
    Looks like an H3 bulb, the lead comes with the bulb. I dont see hows it mounted but seems like the most logical. Google H3 bulb and you should get a lot of hits.
  4. #4
    Platinum Member KYDan's Avatar
    Join Date
    Sep 2011
    Posts
    617
    Frankfort, KY
    Kubota MX5100 HST 4WD
    If you follow the link provided by ThomasH read the reviews. There 4 I think, 2 good, and 2 negative. Both of the negative reviews address bulb life, which was apparently very short.
  5. #5
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Didn't intend to have a Deere fleet - it just happened
    looks like a headlight bulb. The metal base plate is part of the bulb. The new bulb should have a lead too.
  6. #6
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Here's a link to a bulb that looks the same ...
    h3 bulb mounting - Bing Images
  7. #7
    Platinum Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    985
    Oz
    G'day as said it is a H3 globe and it comes with the pigtail on it you will have to pop the rubber grommet out of the base of the light and you should see a blade type connector.
    Jon
  8. #8
    Gold Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    I'm with banjodunn, pull out that little rubber grommet and follow the wire to it's connection point. The glass bulb doesn't come out of it's mount - it's all one piece. Those bulbs blow easily mostly from vibration - especially when they get hot. Good luck....
  9. #9
    Join Date
    Sep 2011
    Posts
    106
    North Carolina
    Kubota B7800
    The bulb runs about $5 to $7 and should plug in somewhere on the other side of the gromet. And the life life can very do to vibration . Some times Wal-mart is closer to $5 , get two then you will have an extra bulb, for next time ...
  10. #10
    Join Date
    Jul 2010
    Posts
    7,935
    Pennsylvania
    Kubota BX25
    Thanks everyone for the help!
    I was looking at the problem all wrong by trying to take out just the bulb and not the whole unit. I found the connector, and the rest was easy. I will look for the replacement bulbs later this week.
    Thanks again.
Similar Threads
  1. BX24 tail light bulb #
    By johnray13 in forum Kubota Owning/Operating
    Last Post: 02-22-2010, 07:39 AM
  2. Replies: 2
    Last Post: 10-08-2008, 10:49 PM
  3. B7510 Hazard Light Bulb
    By PSDStu in forum Kubota Owning/Operating
    Last Post: 11-13-2006, 07:25 AM
  4. Light bulb under oil pan?
    By Wal in forum Owning/Operating
    Last Post: 12-27-2003, 09:02 PM
  5. How many TBNers does it take to change light bulb?
    By Gary_in_Indiana in forum Related Topics
    Last Post: 10-13-2003, 12:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
