Results 11 to 17 of 17
01-03-2013, 05:25 AM #11
Re: JD 4520 Bent Bucket
I don't think I'd be putting chain hooks on that light bucket.
Joy is having the tools you need and needing the tools you have!
Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
01-03-2013, 08:34 AM #12
I wouldn't nix the chain hook idea just yet. They are generally located near the lift arms anyway and that shouldn't affect the center of the bucket. Consider having a heavy flat stock welded across the top, maybe 3/8" by 5 x the width of the bucket, and put hooks or receivers on that. It would be stronger than new. Just an idear.
3720, Frontier 6' BB; 6' Rear Blade.; Loaded tires and Ballast Box; Dirt Scoop.
X740; 62" Deck; w/47" Snoblower; 42" Hydraulic Tiller.
54" Front blade; 48" Belly Blade
01-03-2013, 10:08 PM #13
currently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
01-03-2013, 11:06 PM #14Veteran Member
- Join Date
- Apr 2000
- Posts
- 1,105
- Location
- North Central Arkansas
- Tractor
- John Deere 4520,
Bought my 4520 knowing the bucket would be used to lift heavy loads of muck mud rocks or anything that could not lift with out strain on bucket.
Still new and removed from tractor turned it over . Cut a piece of grader blade and welded it to inside top of bucket. Also welded a piece along the bottom out side of bucket where in draging the wear would be on the grader blade. And after 1200 hours of working the bucket is still in good shape.
Soft strap metal will bend also
ken
01-03-2013, 11:42 PM #15Silver Member
- Join Date
- Mar 2011
- Posts
- 235
- Location
- Pontotoc Ms
- Tractor
- jd 4610
My also got bent when my brother borrowed it. He assumed it would push up a 3 foot oak stump. Brought it home when I was at work and curled bucket upside down so I would not see it. I could not get in touch with him for a month afterward.
After It's been bent It's hard to keep it from happening again.
I took mine an beefed it up (boxed top, 1/2" plate on sides, five 4" skids on bottom) This is my "Give it He**" bucket
It looked like crap it was bent so bad. So I went and bought a new heavy duty bucket just for looks and MY use.
01-05-2013, 10:24 AM #16
I like that ball on the bucket. I may have to borrow that idea!
4710 Deere 4x4 eHydro with 460 Ldr, 48 Hoe, R4's
970 Deere MFWD with 440 Loader, 6' Hog, 5' Woods back blade and a Post hole digger with 8" 12" and 20" augers.
01-05-2013, 11:52 AM #17
currently own
Similar Threads
Bent bucket
By 6sunset6 in forum Parts/RepairsReplies: 11Last Post: 10-08-2008, 09:59 PM -
Bent the 4-in1 bucket
By garth466 in forum Owning/OperatingReplies: 11Last Post: 10-17-2007, 07:32 PM -
bent loader bucket
By Parfleche in forum New Holland Owning/OperatingReplies: 5Last Post: 08-07-2006, 06:22 PM -
Bent Bucket
By Deadfish in forum New Holland Owning/OperatingReplies: 14Last Post: 05-03-2004, 06:23 AM -
Bent the bucket
By mdbarb in forum AttachmentsReplies: 11Last Post: 09-10-2003, 09:32 PM
