Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    23
    Nashville, TN
    Currently tractorless...JD 26G being traded for a new tractor.
    Default JD 4520 Bent Bucket
    I picked up a sweetheart deal on this 4520 with a 400x loader. As you can see from the attached pic, the 40 hours on the clock were hard on the bucket. Otherwise, she's pristine. Any advice on how to persuade the top lip back into position would be appreciated. I've been told not to heat it, and to be careful about bending the bottom while trying to straighten the top. Thanks!
    JD 4520 Bent Bucket-bucketphoto-jpg
  2. #2
    Join Date
    Jul 2012
    Posts
    1,120
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    Default Re: JD 4520 Bent Bucket
    Quote Originally Posted by Nashville View Post
    I would try bottle jacks and blocks of wood.
  3. #3
    Gold Member
    Join Date
    Dec 2012
    Posts
    273
    Grand Lake OK
    Kubota L4600
    I would try tilting the bucket down to get the bottom lip out of the way then putting the bent part over a fence post and using the loader to straighten the top. You will probably need someone to help watch.
  4. #4
    Join Date
    Jun 2008
    Posts
    1,892
    Arkansas!
    JD
    Quote Originally Posted by arlen4720 View Post
    This!! I second the motion -
  5. #5
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    You could try a small body shop or a welding shop, then you spray some paint on it.
  6. #6
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,030
    north idaho
    Kioti DK45SE hst cab
    I had the exact same thing happen to mine when i was younger and stupider than i am today, and wrapped a chain around the bucket to lift something too heavy. i used a bottle jack and piece of wood...worked fine. there was still a minor, nearly unnoticeable crinkle when i was done. JD sells touch up spray paint.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  7. #7
    Silver Member SHORT KID's Avatar
    Join Date
    Feb 2010
    Posts
    180
    Poconos, PA
    Mahindra 2615 hst fel, bh
    I would use a 6x6 top and bottom with a heavy jack.It may still have a wrinkle in it but should be ok. It must be nice to trade or sell your tractor when you make a boo boo!!!!!!!!!
  8. #8
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,175
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    I agree with the jack procedure. Large block of wood on the bottom, to spread out the pressure and keep from making another problem.
    It's really not that bad. I've done worse, and seen a LOT worse.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  9. #9
    New Member
    Join Date
    Dec 2012
    Posts
    23
    Nashville, TN
    Thanks for all the input! I went with pressure treated 2x10s to distribute the weight, and a 12 ton bottle jack. Popped it right back into place like it never even happened. Straight as an arrow. Thanks guys!
  10. #10
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Nice buy, great machine.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
Similar Threads
  1. Bent bucket
    By 6sunset6 in forum Parts/Repairs
    Last Post: 10-08-2008, 10:59 PM
  2. Bent the 4-in1 bucket
    By garth466 in forum Owning/Operating
    Last Post: 10-17-2007, 08:32 PM
  3. bent loader bucket
    By Parfleche in forum New Holland Owning/Operating
    Last Post: 08-07-2006, 07:22 PM
  4. Bent Bucket
    By Deadfish in forum New Holland Owning/Operating
    Last Post: 05-03-2004, 07:23 AM
  5. Bent the bucket
    By mdbarb in forum Attachments
    Last Post: 09-10-2003, 10:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
