Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2002
    Posts
    15
    Default 3 point lift arm turn buckles needed
    I am looking for 2 adjustable lift arm adjusters. If I can not find them, then I need to find some threaded rod and a turnbuckle so that I can make them myself.
    Thanks
    Larry P
  2. #2
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,384
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Default Re: 3 point lift arm turn buckles needed
    What do you drive? I never paid much attention to them, but both my tractors have one adjustable on the right side. I adjusted both one time - just to make the axis of the 3PH pins level. You shouldn't have a hard time finding them.
    If you don't mind me asking, why do you need two? Seems like there should be a pretty good range of tilt in both directions by lengthening/shortening the one side................chim
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    I've seen them at every tractor dealer or farm supply store I've ever been in. If you have a Tractor Supply store in your area, drop in. I've also bought them from the NH dealership, and the Massey fergusion dealership.
    good luck
    Soundguy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
