Results 1 to 5 of 5
01-05-2013, 11:51 AM #1New Member
- Join Date
- Jan 2013
- Posts
- 3
- Location
- Kingsley, Iowa
- Tractor
- New Holland TC40D
New Holland TC40D Won't turn over
I have a 2002 New Holland TC40D with 360 hours on it. I just replaced the battery. All of the lights light strong but when I turn the key to the start position nothing happens. The lights don't pull down so I don't think it's a starter problem. Of course when I called the local dealer that I bought the tractor from new, they weren't much help......didn't even want to come out and look at it.....I would have paid the going rates.....guess that's what happens when a big corporate outfit takes over the local dealers. Any help would be appreciated.
01-05-2013, 01:27 PM #2
Re: New Holland TC40D Won't turn over
See if you're getting power to the (I think it's pink) wire at the starter solenoid. Could be one of two things.
1. bad ignition switch which these tractors can be known for.
2. bad neutral, PTO, or seat safety switch.
If you have a volt/ohm meter, I would start by testing the ignition switch. If it's not, the sticky on the New Holland forum here has a way to setup a relay that works great. My tractor starts better, and doesn't melt ignition switches anymore.
Another test is juggling some of the levers while holding the key in the start position. This can sometimes tell you if something is out of adjustment etc.The forums are a great place to find information....but also a great place to find speculation. Only you can determine the real problems with your tractor. We're here to help you find the correct way to do it.
01-05-2013, 04:07 PM #3New Member
- Join Date
- Jan 2013
- Posts
- 3
- Location
- Kingsley, Iowa
- Tractor
- New Holland TC40D
Thanks for your help. The problem was a blown fuse under the dash and grandkids playing on a tractor....They had engaged the PTO lever and it's cold here now so when I disengaged it the switch was froze.
01-05-2013, 07:41 PM #4
Perfect!!! It's those cheap and easy fixes that we all love to find!
01-05-2013, 08:18 PM #5
Make sure you teach those kids once and for all time not to play with your stuff or else they will show you how to hurt or kill themselves with YOUR stuff. If they run it on a high slope side hill they may show YOU how to roll it over. Then what are you gonna think ? What other machinery around there would like to kill them ?
There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
Similar Threads
New Holland TC40D Manuals?
By Big Al in forum New Holland Owning/OperatingReplies: 2Last Post: 11-08-2009, 10:43 AM -
TC40D turn signal problem
By sigjig in forum New Holland Owning/OperatingReplies: 15Last Post: 09-10-2009, 06:35 PM -
New Holland TC40D
By 602466 in forum New Holland Owning/OperatingReplies: 26Last Post: 08-07-2009, 08:20 PM -
New Holland TC40D Reset Switch
By Windyacres in forum New Holland Owning/OperatingReplies: 2Last Post: 07-23-2006, 09:32 PM -
Starting to turn blue - Thinking TC40D
By lhfarm in forum New Holland Buying/PricingReplies: 17Last Post: 03-26-2005, 11:19 PM
