Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    3
    Mt. Shasta, CA
    Mahindra 2615HST 4WD
    Default Mahindra 2615 HST 4WD rear wheel spacer
    Can't mount rear wheel chains because tires are very close to inside frame. Dealer has no info and could find no aftermarket source. Discovered Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech, owned by Lenny, 1-775-351-1000, Sparks NV. who will custom turn a pair for $170. On my tractor dimensions are 1) flange, the part to which the rim bolts, about 71/4 inches. Non-critical dimension. Could be wider without hitting anything 2) hub diameter 117 mm. Critical measurement, as must fit the tire rim 3) depth of hub (the part that fits into the rim and is flush with the outer edge of the rim) 8 mm 4) bolts are metric 14mmx30mm with 1.5 pitch 6) bolt spacing (6 molts) is ~152 mm center to center between 12 and 6 o'clock bolts. Bolts are 360 deg/6=60 degrees spacing. He can build any thickness. I ordered 1" spacers, which will be milled to fit over existing hub, and bolt to flange using countersunk 14x30mm 1.5 pitch bolts that he will provide. The outer hum will extend 8 mm out to fit the rim. He will tap the holes for my existing 14x30mm 1.5 pitch bolts that will hold the rim to the spacer. Should have in 5 days. $170 + about $15 for shipping. Nice guy to deal with on the phone. Without chains this tractor slides sidewise when I try to clear the burn thrown up by the snowplow on steep roads. No problem fitting chains to the front tires, which alone helps a lot.
  2. #2
    New Member
    Join Date
    Jan 2013
    Posts
    3
    Mt. Shasta, CA
    Default Re: Mahindra 2615 HST 4WD rear wheel spacer
    Mahindra 2615 HST 4WD rear wheel spacer-image-jpgSpacers arrived. Perfect fit! Thanks Lenny.
  3. #3
    Gold Member
    Join Date
    Sep 2007
    Posts
    323
    Texas
    Mahindra 2810, IH Hydro 70, 706
    Cool!!
    More pics!
  4. #4
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,119
    Central Square, NY
    LS XR3037HC
    I had the same problem. My 2615 HST is a 2004 and spacing to the rear frame was only 5/8" with no room for chains.
    I couldn't find anyone who made spacers at the time but another member sent me the attached drawing and I had a machine shop make mine.
    I bought longer bolts at local fastener store.
    Attached Files Attached Files
Similar Threads
  1. REAR WHEEL SPACER ON 2720
    By THOMASLEONARD in forum Customization
    Last Post: 12-30-2012, 10:18 PM
  2. mahindra 2615 hst
    By jerald norman in forum Parts/Repairs
    Last Post: 11-15-2011, 01:56 PM
  3. Mahindra 2615 4WD
    By clarkc58 in forum Ag Tractors & Machinery
    Last Post: 11-08-2010, 02:12 PM
  4. Rear wheel spacer 1914
    By 412driver in forum Kioti Owning/Operating
    Last Post: 10-02-2009, 08:40 PM
  5. Wheel Spacer for JD 4300 HST
    By Bob_G in forum John Deere Owning/Operating
    Last Post: 06-21-2004, 11:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
