Results 21 to 30 of 108
01-14-2013, 04:45 PM #21Silver Member
- Join Date
- Nov 2012
- Posts
- 106
- Location
- Newark, de
- Tractor
- International 424
Re: 8n will fire but not start??
Before you tear into the carb, shut off the fuel and see if it will start on carb cleaner. You need to eliminate the fuel as a problem. I always use Birkbill, but any
type will work. Make sure the Air intake is not plugged too.
01-14-2013, 04:45 PM #22Elite Member
- Join Date
- Feb 2011
- Posts
- 3,873
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
How did the plugs look when you had them out? Where they fouled? If they weren't try shooting some carb cleaner or starting fluid in the carb in the carb and see if it will start. To answer your question earlier Berkebile Gum Cutter is a good carb cleaner. If the starter is kicking out it probably the bendix. You can take it to a starter/ alternator repair shop and get it fixed.
01-14-2013, 06:00 PM #23New Member
- Join Date
- Jun 2012
- Posts
- 22
- Location
- Rice, VA
- Tractor
- Kubota L3800DT
"Starting at the the radiator on the head cover I marked the pistons 1, 2, 4, 3." This could be the problem. The order of pistons in the motor are 1, 2, 3, 4 staring at the front of the tractor moving toward the rear. The firing order is 1, 2, 4, 3. The order the wires need to be on the distributor cap is 1, 2, 4, 3 the way the rotor spins. Could you have wires 3 and 4 be mixed up between the distributor cap and the motor?
01-15-2013, 12:16 PM #24New Member
- Join Date
- Jan 2013
- Posts
- 18
- Location
- Felton, PA
- Tractor
- Ford 8n
I will change them around and see. I will get the Berkebile Gum Cutter tomorrow and order a carb kit. I will see who can do the bendix and get the starter fluid tomorrow and we will see what happens. I did look at the plugs and they seemed like new. They are the dark kind and it was hard to see if they were fouled, but they did still look new. The rest of the tractor behind the dash looks like Leonardo da Vinci installed them and the wires look like they could use a changing as well. I think if I can get it running I will start to buy wires and other components to just have a couple days to just change everything out for new. It is not that much if I get them over time. Thanks and talk to you guys soon.
01-15-2013, 12:17 PM #25New Member
- Join Date
- Jan 2013
- Posts
- 18
- Location
- Felton, PA
- Tractor
- Ford 8n
By the way what is a good carb kit and where could I get one that is the best in your opinions?
01-15-2013, 12:30 PM #26Elite Member
- Join Date
- Feb 2011
- Posts
- 3,873
- Location
- Tractor
If the plugs were dark it sounds like it is flooded. Crank the motor over with the plugs out to blow the gas out. You may be able to clean the plugs with carb cleaner. Put the plugs back in and see if it will start. Tractor Supply or a local tractor dealer that sells TISCO should be able to get a carb kit and a wire harness. I don't know if you really need to mess with the carb right now. Good luck and let us know what happens.
01-15-2013, 12:43 PM #27Elite Member
- Join Date
- Feb 2011
- Posts
- 3,873
- Location
- Tractor
I wanted to add that if the starter is kicking out it will make it hard to start and easy to flood.
01-15-2013, 01:55 PM #28Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,146
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
interesting thread going here... i see plenty of things going on... hmm..
01-15-2013, 03:57 PM #29
01-16-2013, 10:38 PM #30Elite Member
- Join Date
- Feb 2011
- Posts
- 3,873
- Location
- Tractor
Any updates????????
Similar Threads
Ever start a fire?
By QwikDraw in forum Land ClearingReplies: 32Last Post: 09-10-2011, 02:02 PM -
satoh s650g fire to plugs, still wont start
By twistedgfarm in forum Mitsubishi/SatohReplies: 5Last Post: 05-23-2011, 10:44 PM -
How to Start a Barrel Fire..Georgia Style
By walkin2e in forum Rural LivingReplies: 35Last Post: 02-07-2009, 09:23 AM -
Help me start a FIRE !
By Mrwurm in forum Rural LivingReplies: 39Last Post: 12-06-2003, 06:58 AM
5
