Page 5 of 11 FirstFirst ... 2345678 ... LastLast
Results 41 to 50 of 108
  1. #41
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,061
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 8n will fire but not start??
    or here.. though I'm sure this willcome to a shock to Don.
    'hard to believe' my but. Helps when you know what you are talking about....
  2. #42
    New Member
    Join Date
    Jan 2013
    Posts
    15
    Felton, PA
    Ford 8n
    yes, I am iced in and just got a new Powermatic Tablesaw. I am trying to get that put together and get all this crap out of my woodworking shop, which is my two car garage, to make room to get the tractor back in, it has been windy and cold so sitting outside is not good until the wind dies down and I can spray the starter fluid to see what happens. I have read other threads on other sites and most the have an original carb just put a new float and rebuilt it and they were good. I posted a new thread asking if anyone knew where I might get a couple 3 X 19 wheels for the front of my tractor. That salt water eat the back two up and I replaced them and now the front are going to go. May as well change them out while I am at it.
    You know, I can leave the 3 point hitch up and come out the next morning and it will still be up. It may have fallen an inch. This is a good tractor. no oil leaks and it is sound and will be again. I will keep everyone posted.
  3. #43
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,800
    NOT HERE
    Quote Originally Posted by parispete View Post
    Thanks for the update. Anyone that sells TISCO should be able to get you some wheels which would be most tractor dealers.Tisco Tractor Part Mart: Reliable Tractor Parts You Need. Fast :: RIM 19X4.00 6 BOLT (8N1015A) Do you have fluid in your tires? If you have calcium in them it will eat the wheels up.
  4. #44
    Member
    Join Date
    Dec 2012
    Posts
    37
    Orillia Ontario
    50&51 8N Ford
    Hi Pete I've read all of this & from the fact that this started when you were working it . Mine did a similar run rough & hard start, turned out to be the head gasket burnt between 2&3 cylinders ,on my 51. Now on my 50 it was just simply two plug wires mixed up. Wouldn't be too concerned about carb kit ,both of mine ran fine after disassembly & cleaning with spray cleaner ,one sat 2years the other for 4.5 years .Just my
  5. #45
    Gold Member
    Join Date
    Jan 2013
    Posts
    356
    jackson,oh
    918 allis-chalmers
    Well,I guess you fellas have never timed an engine by marking the crank pulley? Or are you saying there is NO crank pulley? I'm saying that this is the absolute best way to time an engine. According to CarlK's link,the timing is not so foolproof as SG makes out.
    I'm also telling Pete that the distributor could be sending intermittent spark. PROBABLY Pete has a fuel problem,but there are MANY things that can go wrong with simple ignition systems also.
    I'm a mechanic,in general,and i have not claimed to be a tractor specialist. don-ohio (:^)
  6. #46
    New Member
    Join Date
    Jun 2012
    Posts
    22
    Rice, VA
    Kubota L3800DT
    So how do you determine TDC on an 8N?
  7. #47
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,617
    Nova Scotia, Canada
    Flathead = plug wrench and something long that fit's in the plug hole.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  8. #48
    New Member
    Join Date
    Jun 2012
    Posts
    22
    Rice, VA
    Kubota L3800DT
    Easier said than done on an 8N. The spark plug hole in the head doesn't line up with the piston. There is also very little room between the head and the gas tank. I successfully statically timed my front mount 8N the first time I tried it using the I&T manual. Its really easier than it looks. I copied these photos off Yesterday's Tractor site. Its the best source of info on old tractors. I suggest Pete also search there for help.
    Attached Thumbnails Attached Thumbnails 8n will fire but not start??-flat-head-spark-plug-hole   8n will fire but not start??-sparkplug_location.jpg
  9. #49
    Join Date
    Aug 2001
    Posts
    16,617
    Nova Scotia, Canada
    Guess I should have added Coat Hanger Wire.
    Egon
    Livin in a
  10. #50
    Join Date
    Mar 2002
    Posts
    42,061
    Central florida
    Quote Originally Posted by don45640 View Post
    why booger something when the CORRECT way is easy.
    Besides.. getting tot he crank pulley requires a pocket gnome and minature ant sized tools. it's cramped up there with a front mount.
    Ahh.. so you are saying that you know MORE than the engineers that designed and built the N... as they are the ones that devised the way to static time it.
    I'm happy to meet someone that knows more than the people that designed the machine did.
    wow...
    so... you never worked on one eh?
Similar Threads
  1. Ever start a fire?
    By QwikDraw in forum Land Clearing
    Last Post: 09-10-2011, 02:02 PM
  2. satoh s650g fire to plugs, still wont start
    By twistedgfarm in forum Mitsubishi/Satoh
    Last Post: 05-23-2011, 10:44 PM
  3. How to Start a Barrel Fire..Georgia Style
    By walkin2e in forum Rural Living
    Last Post: 02-07-2009, 09:23 AM
  4. Help me start a FIRE !
    By Mrwurm in forum Rural Living
    Last Post: 12-06-2003, 06:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
