Results 1 to 7 of 7
01-12-2013, 01:59 PM #1New Member
- Join Date
- Jun 2012
- Posts
- 7
- Location
- auburn new york
- Tractor
- walk behing power drive 21
1982 Ford F-1200 front diferential oil change?
does anybody know how to check or change the front differential oil on this tractor?
01-12-2013, 09:44 PM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,124
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 1982 Ford F-1200 front diferential oil change?
what's yer manual say about plug locations?
01-12-2013, 10:40 PM #3
01-13-2013, 03:27 PM #4Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,309
- Location
- Buckner MO
- Tractor
- 2005 Kubota L5030 GST; Farmall 706
OP
Sorry for our comments which may have been out of line. I see where you are new member, and previously posted for help locating a manual.
TBN and its members will usually bend over backwards trying to help........I don't know the answer to your question...BUT, I did find an owners manual here:
http://www.ssbtractor.com/tractor_ma...ual_model=1200
They also have a service manual ...but it is very pricey.
Hope this helps, and WELCOME to TBN.Dean
"Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
01-14-2013, 10:09 AM #5
01-14-2013, 10:11 AM #6
01-14-2013, 04:45 PM #7
I & T FO-44 shop manual not so pricey and not as much help covers the Ford 1200. It does not show the drain plugs on your model but the 1700 (same vintage) has three drain plugs, center section and the gear reduction housings on each end.
Similar Threads
1992 jd 855 mfwd front diferential lube ?
By Grumpy Old Man in forum Parts/RepairsReplies: 2Last Post: 11-15-2012, 01:17 PM -
1982 Ford 7710 FEL Control Change
By spollan in forum HydraulicsReplies: 12Last Post: 10-03-2012, 05:12 PM -
DK 55 Front axle oil change
By qwerty123 in forum Kioti Owning/OperatingReplies: 3Last Post: 07-01-2012, 07:12 PM -
Oil & Fuel Ford 1200 4 x 4 Front Differential
By jimb1 in forum New Holland Owning/OperatingReplies: 4Last Post: 02-02-2012, 03:07 PM -
ford 1200 front loader?????
By bigwedgies in forum FordReplies: 0Last Post: 07-25-2010, 10:45 PM
