Results 1 to 4 of 4
  1. #1
    Veteran Member lhfarm's Avatar
    Join Date
    May 2002
    Posts
    1,126
    Central Indiana
    NH TC40DA
    Default Help with Hydraulics - slightly OT
    This is sorta off topic so hope you don't mind me asking. We are restoring a 1947 jeep as a farm vehicle,complete with 3pt hitch. The first 4 wheel drive compact!
    The hitch fits under the rear of the jeep and has its own reservoir and valve. The original pump would have been driven off the crank, with lines running to the rear. The valve is mounted on the reservoir and is spring loaded to return to netural. There is a control between the seats and one out the rear for moving the valve and controling the lift.
    We have an old electric pump (12v)with its own reservoir, but no control valve. I have the outlet of the lift reservoir connected to the reservoir of the pump. The cylinder has been rebuilt, but the valve hasn't been touched.
    The pump lifts me standing on the arms, but as soon as the valve is in the netural position the lift drops. I am trying to determine if I have air in the system or if the valve needs a rebuild. Also, am I going to have problems running two reservoirs? When the pump is mounted in the engine compartment, it will be at about the same
    height as the lift reservoir.
    Any help or suggestions greatly appreicated.
    Barry
    www.farmjeep.com
  2. #2
    Elite Member
    Join Date
    Jul 2003
    Posts
    3,373
    Goffs Corner, KY
    IH 2444
    Default Re: Help with Hydraulics - slightly OT
    Not at all familiar with this system, I would think few are though. I would think that you problem is in the valve. Just my opinion though. I have been wrong before.
  3. #3
    Join Date
    Jul 2003
    Posts
    51
    Maine
    Kioti DK 45
    Sounds to me like the valve also. Different valves are made to do different things. Sounds like your's is made with a float center position. It's worth looking into what the valve positions actually do. You may be able to buy one cheap to match your needs on the hitch.
    good luck.
  4. #4
    Join Date
    Jul 2003
    Posts
    85
    NW Washington State
    Bolens hydro, BX22, 1952 MM RTU
    I built a three point for my farm tractor using the belly lift hydraulics which have a center float position. That sounds like the type of valve you may have. I put ball valves in the lines to the 3pt top cylinder. I lift the impliment to the height I want and then close the valve to hold it there. Not the most elegant set-up, but it did not cost me anything and works well...
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
