Results 1 to 9 of 9
  1. #1
    Gold Member
    Join Date
    Jan 2013
    Posts
    356
    jackson,oh
    918 allis-chalmers
    Default Here's a brain teaser to troubleshoot! AC 2800 diesel in-line 6
    Okay.......the other day,while changing out my Tractor/loader/ backhoe's antifreeze,which was a problem in itself finding the proper antifreeze for silicone ring sealed wet-liners,I caused a problem unknown to me at that time.
    Since I have solved it because I'm right here able to troubleshoot, I thought maybe I'd run the symptom by everyone and let them take stabs at the solution.
    While taking out 2 plugs I THOUGHT were antifreeze block drain plugs,I had to put tremendous torque on them to remove them.Turned out they were only blank crankcase plugs.
    Well,I found the right plug hidden behind the air-bleed plunger,so I moved the plunger by taking the fuel line loose.
    Now while doing this hi-torque wrenching(hadda use my leg to move the breaker bar),I put a small dent in the body of the fuel filter which is a spin-on NAPA #3354 BTW. I went ahead and plungered the air out of the system flling up the fuel filter.
    With cold weather imminent, I wanted to start the backhoe and get the antifreeze circulated and top it up completely.
    So, I proceeded to try to start the engine and even used a little ether,but to no effect.Only thing I got was white smoke,a lot of it! LOL!
    Okay,what would cause all that white smoke and a no-start condition in a machine that always starts like it's summertime? don-ohio
  2. #2
    Join Date
    Mar 2008
    Posts
    829
    southwest NH
    Kubota L5240
    Default Re: Here's a brain teaser to troubleshoot! AC 2800 diesel in-line 6
    Sounds like you are air locked. I would loosen the fuel filter and wait till the fuel runs over then you may have to loosen the fuel line into an injector to let the air out. Don't you just hate it when something is fine till you fix it !
    'Master of a thousand indispensable skills destined to keep him at the poverty level'
    'You can't beat a man at his own trade'
  3. #3
    Platinum Member Heywood Jannockitov's Avatar
    Join Date
    Jan 2008
    Posts
    703
    Near Schomberg, Ontario Canada, the equestrian center of the universe
    2008 John Deere 5425 cab, 1986 Case 580 Super E, 1973 IH454
    It's getting fuel if there's white smoke. Slipped the timing somehow?
    Definition of "Horse": A 4 legged mammal looking for an inconvenient place and expensive way to die.
  4. #4
    Gold Member
    Join Date
    Jan 2013
    Posts
    356
    jackson,oh
    918 allis-chalmers
    HaHaHaHa! Yes,GC! I do hate it when one problem leads to another. That is a very credible answer, and I actually got back off the tractor and bled it out again,thinking like you have that air is the culprit. You're definitely CLOSE,but I had to do something else to correct the situation. don-ohio (:^)
  5. #5
    Join Date
    Mar 2008
    Posts
    829
    southwest NH
    Kubota L5240
    Knock a wire loose ?
  6. #6
    Super Member murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    6,492
    Ohio
    Kioti DK 40-Massey ferguson 135-Simplicity Conquest
    Quote Originally Posted by don45640 View Post
    Like change that dented fuel filter
    Murph ------------ Sent from my HP laptop
    Nothing runs like a Deere when being chased by a Kioti
  7. #7
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    3,787
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by murphy1244 View Post
    ...+1 or tighten it up because the 'whack' loosened it enough to suck air.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  8. #8
    Gold Member
    Join Date
    Jan 2013
    Posts
    356
    jackson,oh
    918 allis-chalmers
    Yep,Murphy! That's what it took. I had loosened the fuel filter just enough to allow air inside. Thank goodness,Heywood,it wasn't a timing thingy,or I'd been up the creek on that engine. don-ohio (:^)
  9. #9
    Gold Member
    Join Date
    Jan 2013
    Posts
    356
    jackson,oh
    918 allis-chalmers
    Yeah,Don! I just saw what you posted.That may have worked,but I MAY have warped that filter,so I chose to run to Jackson Implement and get a new one. don-ohio (:^)
Similar Threads
  1. Replies: 7
    Last Post: 01-16-2013, 10:06 AM
  2. Teaser rain
    By pennwalk in forum Rural Living
    Last Post: 05-21-2008, 03:24 PM
  3. some 5000 teaser pics
    By Soundguy in forum General Vintage Tractors
    Last Post: 11-26-2005, 12:16 AM
  4. Brain Teaser in Wood...
    By DIYGuy in forum Related Topics
    Last Post: 10-30-2003, 01:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
