Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    New Member
    Join Date
    Oct 2012
    Posts
    9
    Rainbow Reach NSW
    Landini Atlas 75
    Default Re: Power steering fluid squirting out of the oil Reservoir breather hole
    Thank you for your reply. I have found the cause to my problem the tractor has hydrostatic power steering, in the steering valve (that's what the steering column connects to) there is a built in relief valve the relief valve is damaged and passes the fluid back to the reservoir through the return line. I would like to thank everyone for their help on this problem.
  2. #12
    Super Member
    Join Date
    Dec 2007
    Posts
    5,665
    Canada
    Ford 3930
    Quote Originally Posted by mlswr View Post
    Always good to finally figure it out. Thanks for letting us know; that's one I haven't seen.
    Rgds, D.
  3. #13
    New Member
    Join Date
    Oct 2012
    Posts
    9
    Rainbow Reach NSW
    Landini Atlas 75
    I have attached a picture of where the relief valve is to help anyone in the future with a similar problem
    Power steering fluid squirting out of the oil Reservoir breather hole-valve-jpg
  4. #14
    Super Member
    Join Date
    Dec 2007
    Posts
    5,665
    Canada
    Ford 3930
    Is that valve serviceable separately, or does that mean you need a new pump ?
    Rgds, D.
  5. #15
    New Member
    Join Date
    Oct 2012
    Posts
    9
    Rainbow Reach NSW
    Landini Atlas 75
    I am buying a new pump my tractor has a bit over 4000 hours, I may save downtime later by replacing the pump. I haven't been searching for a relief valve to know if it can be bought separately a new pump costs $399 US
  6. #16
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    Did you see this damaged relief valve or did someone tell you??
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  7. #17
    Super Member
    Join Date
    Dec 2007
    Posts
    5,665
    Canada
    Ford 3930
    I don't change enough of these to know for sure, but that doesn't seem like a bad price to me. For something that I rely on, I'd make the same choice.
    Rgds, D.
  8. #18
    New Member
    Join Date
    Oct 2012
    Posts
    9
    Rainbow Reach NSW
    Landini Atlas 75
    I took the steering valve to the hydraulic repair shop to get it tested and they rang me, I picked it up yesterday and I thought I would have a look I took the spring out and tapped and shook the unit but I couldn't get anything else out, probably needs compressed air behind it to pop it out
Similar Threads
  1. Replies: 1
    Last Post: 09-04-2012, 04:51 PM
  2. Leaky Power Steering Reservoir
    By jrinck in forum New Holland Owning/Operating
    Last Post: 06-02-2011, 02:54 PM
  3. ATF instead of UTF in Power Steering Reservoir.
    By 2dawoodz in forum New Holland Owning/Operating
    Last Post: 04-20-2010, 10:56 AM
  4. B&S 13 HP Oil Breather Compartment Hole
    By Phredrick in forum General Lawn & Garden
    Last Post: 08-23-2008, 03:02 PM
  5. Power Steering reservoir leak
    Last Post: 05-16-2006, 10:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
