Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Delta 36-220 wood chop saw
    weird....in any case.. I'll tell him to check the comutator and the brushes
  2. #12
    Platinum Member Steave's Avatar
    Join Date
    Mar 2012
    Posts
    845
    Taylorsville, GA
    3000 Ford 66' 260A International Backhoe, Belarus 250AS
    The brushes short to each other when off. Here's a wiring diagram, go to page B diagram at bottom right of page.
    In the diagram it shows some squiggly symbols on the Brake wires from the switch. Don't know what these are??
    Delta 36-220 Parts List and Diagram - Type 3 : eReplacementParts.com
    I've got a cutting torch and a welder sooo YEAH it'll fit!!
  3. #13
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    i've got the link.. it's just the size of a quarter on a telephone though..
    I tried stretching it and it ust got fuzzy.
    but brushes shorted to each other sounds good. thanks
  4. #14
    Join Date
    Jun 2007
    Posts
    228
    Middle of west TN
    JD: LX172, X740, 3520
    Soundguy,
    Kevinwak is correct. The "brake" circuit works with much lower power (voltage) than the "run" circuit and therefore is much more sensitive to poor commutation.
  5. #15
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    that makes sense.
    I'll have my buddy checkt he comutator and the brushes, and check the wires on the 2nd part of the switch ( Off position ) to see if the wires tot he brushes are intact.
    next would be the switch contacts.
    My buddy is not electrically inclined.( but he is smart as a whip, clever, and mechanically inclined / experienced tractor fixer-upper.. ).so this is gonna be an uphill struggle over the phone.
  6. #16
    Join Date
    Jun 2007
    Posts
    228
    Middle of west TN
    Steave,
    Actually, when the switch is off the brushes are connected to the fields (those squiggly lines) directing generated power (from a coasting motor = generator) back into the commutator causing the armature to be driven in reverse.
  7. #17
    Join Date
    Mar 2012
    Posts
    845
    Taylorsville, GA
    Quote Originally Posted by Soundguy View Post
    Did you click on the page before enlarging?? It's not clear but readable. Do you use (Ctrl +) for enlarging?
  8. #18
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    yes I clicked onthe page.. but remember.. i don't own a conventional PC.. I'm on mobile devices 99% of the time.
    my largest screen is a medium tablet .. smaller than a ipad..e tc..
  9. #19
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Delta 36-220 wood chop saw-email012-jpgok.. i had my buddy clean the brushes and the comutator.. though he said they looked ok.
    he drew a pictoral. shows 2 wires to the brushes.. the blk/wht to the power cord and 3 wires to the motor.. all from the switch...
    if i can get him to use an ohm meter ( IF ) what is the best bet to get him to check to see if the switch is working correctly to dump motor to brush
  10. #20
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Quote Originally Posted by Steave View Post
    that diagram is about an inch on my telephone.. like I said before 2-3 times now... I don't own a pc with one of them nice big monitors on a desk... I work off mobile devices with screens and keyboards the size of phones.. my biggest machine is a small form factor tablet pc with a screen a couple inches SMALLEr than an ipad... OR an iphone 3gs.
    I will have to see if I can email it to someone to print for me as I can't see anything with enough resoloution to tell what those wires and switch contacts say. i see what looks like a dpdt switch.. but that's it..
    i'll maybee run by the office on the way to the jobsite and see if i can't print it.
    if i could SEE the switch contacts on the diagram, I'd know what wires were being connected via switch when open and in closed position
Similar Threads
  1. Delta faucet help
    By schmism in forum Projects
    Last Post: 01-29-2012, 10:05 PM
  2. Delta Scroll Saw
    By bigtiller in forum Related Topics
    Last Post: 10-31-2011, 05:13 PM
  3. Surplus Delta Chop saw restoration
    By Millsonwheels in forum Projects
    Last Post: 03-21-2010, 07:24 PM
  4. Can a wood chop saw bw used for metal cutting?
    By hz293 in forum Build-It Yourself
    Last Post: 11-11-2006, 10:09 AM
  5. delta unisaw
    By ejb in forum Rural Living
    Last Post: 08-06-2003, 12:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
