pharmvet
- Joined
- Sep 28, 2008
- Messages
- 535
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Well, I just posted 2 days ago about how proud of myself I was for shortening the drive shaft in my Bush Hog 406 and this afternoon I suffered a setback. I was shredding some pretty large brush/trees (approx. 2-1/2 to 3" diameter). I heard a different noise and looked back to find that my PTO shaft had come apart at the gear box. I immediately shut off the PTO and idled down the tractor for inspection. Upon closer examination I found that the drive shaft just rearward of the slip clutch had come off the gear box input shaft. As I mentioned in my post regarding shortening the shaft, I ran this shredder for about an hour last year. Other than that, this is the first time I have run it. It appears that there should be a bolt of some sort going through the male and female portion of the connection. Im not sure if this is a shear pin or a regular bolt. I suspect either one of 2 things happened"
1) The shredder came from the dealer without a bolt/shear pin.
2) My using it last year with the drive shaft being a tad too long put pressure parallel to the shaft and broke the pin/bolt, and using it just vibrated it apart.
Anyway, any and all suggestions and explanations on what I broke and how to fix it are welcomed.
