Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    2
    Minnesota
    1998 Bobcat 863 F-Series
    Default 1998 863 F-Series Bob cat that blows fuse each time you turn the key on
    We have a Bobcat, 1998, F-series 863 that has recently started to blow the fuse each time you turn the key on. Any suggestions for what is going on with it would be greatly appreciated.
  2. #2
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,152
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Default Re: 1998 863 F-Series Bob cat that blows fuse each time you turn the key on
    I'm assuming your key switch it at the left top front of the ROPS like many. Is there a particular function you have turned on, such as lights etc..?? Do you have a manual showing which particular fuse is blowing..??
    I had the fuse for the lights on my 450 blow. Insulation was worn off the wire up behind the ign. switch panel, and shorting out, shutting the whole unit down.
  3. #3
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,761
    South West MI
    John Deere 2030, John Deere 6415
    You must have short to ground. Rig a light (voltage same as machine, 12, 24 etc) across the fuse that's blown.
    The light will be "on" rather than a fuse blowing, allowing you to search for the short.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  4. #4
    New Member
    Join Date
    Feb 2013
    Posts
    2
    Minnesota
    Thankyou for your replies. The information we found on here helped. If we have another problem I will get your replies to my husband.
    It was the glow plug that was shorting if that is how you say it. He disconnected it. Like I said, we may be back if more falls apart...lol... it is an old machine. ty very much. This is a good site.
Similar Threads
  1. Fuse keeps blowing when I turn the key (JD L118)
    By anthem3 in forum Parts/Repairs
    Last Post: 10-07-2012, 04:01 PM
  2. GT1045 Blows Fuse
    By jerry1980 in forum Cub Cadet L&G
    Last Post: 05-27-2012, 10:41 AM
  3. 451 blows fuse
    By purplewg in forum Massey Ferguson Owning/Operating
    Last Post: 08-12-2010, 03:14 PM
  4. 1863 blows 20amp fuse as soon as key is turned on
    By TomH5304 in forum Cub Cadet Tractors
    Last Post: 08-17-2009, 09:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
