Results 1 to 6 of 6
02-08-2013, 11:19 AM #1New Member
- Join Date
- Feb 2013
- Posts
- 8
- Location
- Lawrenceburg, TN
- Tractor
- ~1959 Allis Chalmers
AC D14 Mysterious Fluid Leak
There is this moist area on the right side of my AC D14 at the area you can see in the pic. I have recently purchased this tractor and have not given it a bath yet, so I do not know if it actually is progressively getting worse or actively leaking. Just wondering where I should start on troubleshooting, what it could be, and if I should be concerned? The tractor starts and runs great. Thanks.
02-08-2013, 12:51 PM #2Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,523
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
Re: AC D14 Mysterious Fluid Leak
Guessing that is the hydraulic fill cap, and probably behind that sheet metal is where part of the hydraulic system is. Possibly a connection weeping. Pull the side panels, and look for washed areas where oil may have leaked.
02-08-2013, 05:48 PM #3
02-08-2013, 06:08 PM #4Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Those old iron tractors tended to have some minor leaking at the seams. I would look behind the panel to see if something was loose but unless it is really leaking badly in like a puddle under the tractor after parking or if it leaks worse when running , I wouldn't worry too much about it, just top up the oil occasionally.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-09-2013, 05:33 AM #5Gold Member
- Join Date
- Jan 2013
- Posts
- 356
- Location
- jackson,oh
- Tractor
- 918 allis-chalmers
02-09-2013, 05:01 PM #6Gold Member
- Join Date
- Jan 2012
- Posts
- 353
- Location
- Industry, Pa- - 5 mi. north of Ohio River
- Tractor
- Kioti DS4510, Ford '48 8N, Ford '53 Jubilee, Power King 1614
With that dark ring around the bolt by the fill port, I believe that is what is leaking. check it for tightness and if loose, I would remove it and put a little pipe dope on it and reinstall. Threads do wear after years of use and
vibration. Just my
for today. Let us know what you find.
TomKioti 2012 DS4510 with FEL
Ford 1948 8N
Ford 1953 Jubilee
Power King 1614
Various 3 pt. equipment
Sold: Ford 1946 2N, Kioti 2011 DS3510
Similar Threads
'New' A-C D14
By jtheise4 in forum General Vintage TractorsReplies: 7Last Post: 05-08-2011, 01:05 PM -
Mysterious leak - B2710
By Alan L. in forum Kubota Owning/OperatingReplies: 3Last Post: 04-06-2010, 10:58 AM -
Any D14 owners?
By slehrmann in forum General Vintage TractorsReplies: 12Last Post: 09-19-2008, 09:50 AM -
Mysterious water leak, might end up being a project
By ericbx1500 in forum ProjectsReplies: 12Last Post: 01-24-2007, 10:34 AM
