Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    Kubota B7800 with FEL
    Default Re: torque wrench recommendations please
    I have one of these and it works very well.
    http://www.skhandtool.com/products/torque-wrenches.aspx
    ........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
    jerry clowers-a coon huntin story.
  2. #12
    Member fordoutback's Avatar
    Join Date
    Apr 2012
    Posts
    46
    Upstate, NY
    Mahindra 4035
    Quote Originally Posted by daugen View Post
    I've got a torque wrench and hardly ever use it. My bad. It's a no name manual and i just don't trust it. Why I don't know...
    Would an inexpensive HF digital gauge be more accurate than a more expensive manual "clicker"?
    is a clicker style adequately accurate?
    Say for a hundred bucks, which I don't think is unreasonable for a precision tool, that would go up to say 200 pounds,
    what do you all recommend? I know the pro models are way more expensive than this, but can one get good precision for installing
    car/truck wheel lugs, mower blade nuts, etc.? Not little stuff but not working on a nuclear plant either.
    I have had an S-K clicker wrench for a while now. I think it goes for $100-$125 still today. I bought it at my local Car Quest dealer. You might have some around you in PA. I have had this wrench recalibrated twice through the years when dropped and they said there were no issues. I think the warranty is one year including calibration. Myself, I wouldnt trust a Craftsman one anymore. My son bought one and it just doesnt feel right.(read the reviews and you will understand) Any torque wrench will work for every day AVERAGE jobs, but for anything else I like the S-K. It's rated from 20 to 150 ft lbs and you are supposed to turn it back down to the lowest setting after use.
    The more I want to get something done, the less I call it work..........
  3. #13
    Join Date
    Apr 2012
    Posts
    46
    Upstate, NY
    Mahindra 4035
    You must have posted this while I was writing mine, lol Referring to the post from whistlepig
  4. #14
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    There was another thread on torque wrenches not too long ago. SK torque wrenches had some good recommendations by other TBN members. All my socket sets are SK. They make an excellent tool. I prefer SK over anything else.
  5. #15
    Join Date
    Feb 2012
    Posts
    1,670
    Holland, PA
    2012 Kubota L5740HSTC3, 1986 Case IH 255, 1986 Gravely 8199G
    this is really helpful, thank you guys. If I can find a good SK clicker for 125 bucks, that sounds like a good solution. SK has always set minimum quality standards, and certainly have raised their prices to meet them.
    But I'm looking for a lifetime tool (not hard to do when you're 63...)
    It would be nice if the place selling them also provided a calibration service. I think our local Napa might have this tool, but geez, I always feel like I'm getting hosed when I go in there, since I don't have a commercial discount.
    2012 Kubota L5740HSTC3 with FEL and Long grapple, 1986 Case IH 255, Land Pride PD10 PHD, Land Pride RCR60 mower, Land Pride box blade and rear rake, Fred Cain subsoiler, County Line potato plow, County Line 1 bottom plow, 1986 Gravely 8199G with tow behind DR rototiller, 50" deck+40" Gravely wing mower, Gravely snowblower, Swisher 44 rough cut mower,Ariens snowblower, Echo 450-18 & 600-24, Echo PPT280, 2006 JD LX280, , 1968 Cub Cadet 125, Husky-Speeco 35 ton splitter 2012 Suburban 2500
  6. #16
    Join Date
    Dec 2007
    Posts
    861
    Quote Originally Posted by mvwicker View Post
    I have both types, and can test my clickers against my split beam torque wrench pretty easily. I just find the right socket to join the two and then check a few settings on the clicker against the value indicated on the split beam. Split beams are simpler, as has been pointed out, and retain their calibration essentially indefinitely.
    Convenience is the main advantages of the clicker type. The convenient tool is the one you will use. Sometimes the torque setting is really important, and the bolt or nut is in a hard-to-access spot, like the drain bolt in an oil pan. Who wants to read a scale 2" from one's nose while laying under a tractor? Before I got the clicker I would mark the a spot on the back side of the split beam's scale so I could read it upside down, but that didn't always make it visible.
    As for digital torque wrenches, unless they beep they have the same problem as the much cheaper split beam wrenches. Plus, their batteries might fail, and just because they show lots of significant digits doesn't mean they are accurate.
    Hi MV - there might be regional differences in the terminology, but I think you are describing the basic defecting-pointer-over-a-numbered-scale-plate type ($15 or so) when you say split-beam - I'm going on your description of marking the back of the scale.
    Just fyi, not trying to nitpick...... It took me a bit of research to track down a real split beam - oversimplifying a bit, you essentially have 2 torsion bars, enclosed in the handle of the wrench. It does click when it hits your preset limit, but there is no spring to worry about. Pricing is $100+ typically.
    (Went looking for an exploded diagram of a split-beam design - I've seen one, but just can't seem to pull it up right now).
    I take good care of my tools, and rarely lend 'em, but liked the rugged design of the split-beam.
    I've always heard good things about SK, that should be a nice one if that is what you pick up Daugen.
    Rgds, D.
  7. #17
    Elite Member 94BULLITT's Avatar
    Join Date
    Feb 2011
    Posts
    3,845
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    For most applications a click type torque wrench is best because it is fast and easy to use. I saw a harbor freight tested on youtube against a snap on and it was off 10% which is not acceptable for critical fasteners. I would look for a good used snap on and test it against a known to be accurate torque wrench. You could pick up a used 1/2" snap on for around a $100.
  8. #18
    Join Date
    Dec 2007
    Posts
    861
    Quote Originally Posted by 94BULLITT View Post
    Precision Instruments was the OEM for SnapOn for a very long time.
    Rgds, D.
  9. #19
    Join Date
    Feb 2011
    Posts
    3,845
    Quote Originally Posted by 3930dave View Post
    Rgds, D.
    I think now it is CDI, which I think Snap On owns.
  10. #20
    Join Date
    Dec 2007
    Posts
    861
    Could be. In the industry I know, most companies spend a lot of time trying to bankrupt their suppliers, so I'm not surprised when a quality supplier stops doing business with a major customer.
    Just a guess on my part, but often is the case.
    Rgds, D.
Similar Threads
  1. Using a torque wrench...
    By SonnieP in forum Mahindra Owning/Operating
    Last Post: 09-12-2005, 05:55 PM
  2. Torque Wrench
    By JohniusMaximus in forum John Deere Owning/Operating
    Last Post: 04-21-2005, 11:51 PM
  3. Torque wrench
    By Haz in forum Owning/Operating
    Last Post: 05-13-2003, 10:25 AM
  4. Torque Wrench
    By MikePA in forum Related Topics
    Last Post: 07-21-2002, 01:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
