Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    12
    Lexington, KY
    None
    Default John Deere 1050 Exhaust Manifold Removal
    I'm working on a John deere 1050 and trying to remove the exhaust manifold and turbo. I have a tech manual and have done everything it has said to do. I removed the three bolts and one nut and it won't budge. Any suggestions? My final goal is to remove the cylinder head and replace the head gasket.
  2. #2
    New Member
    Join Date
    Jan 2013
    Posts
    12
    Lexington, KY
    None
    Default Re: John Deere 1050 Exhaust Manifold Removal
    I just realized they are not bolts, but threaded on both ends. On three of them, the entire bolt came out. On one of them, the nut came off. Here is a picture. If you click on the image, you can see where I have a black circle around the one where the nut came off and a red circle around one of the other holes. John Deere 1050 Exhaust Manifold Removal-1050manifold.jpg
  3. #3
    New Member
    Join Date
    Jan 2013
    Posts
    12
    Lexington, KY
    None
    Any ideas out there?
  4. #4
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    597
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31, IH 1486, MF 135
    Default
    Isnt that tractor a 3 cylinder? If so, you should have atleast 6 bolts or studs holding the manifold on. 2 per cylinder.
  5. #5
    Join Date
    Apr 2011
    Posts
    61
    X748
    Default
    Sometimes the manifold will get seized on the studs from corrosion. I would hit them with pb blaster penetrating oil and let but sit overnight, then, lightly tap the manifold with a hammer. It also helps if you put the nuts back on the studs just till they are even with the end, then tap with an hammer, or lightly with an air hammer.Patience is key!
  6. #6
    Join Date
    Jul 2000
    Posts
    202
    Western,MA
    JD 850, L130, 317
    Looks like 9 studs or bolts in the picture
    Attached Thumbnails Attached Thumbnails John Deere 1050 Exhaust Manifold Removal-rp1379_________un01jan94.gif
  7. #7
    New Member
    Join Date
    Jan 2013
    Posts
    12
    Lexington, KY
    None
    That was it. There are 6 bolts. That's what I get for just reading the technical manual. It is a 3 cylinder. Thanks everyone!!
  8. #8
    Join Date
    Feb 2012
    Posts
    597
    Summit. Ms
    Default
    Looks like 9 to me also. Agree with the penetrating oil and a hammer. I always tap with the hammer handle instead of the steel end though. Those cast iron manifolds can break fairly easily when hit with a hard shock from a steel hammer.
  9. #9
    New Member
    Join Date
    Jan 2013
    Posts
    12
    Lexington, KY
    None
    Another question. In order to remove the cylinder head, do you have to remove the rocker arm assembly?
  10. #10
    New Member
    Join Date
    Jan 2013
    Posts
    12
    Lexington, KY
    None
    I went ahead and removed them, took the little cap off of the valves, and removed the push rods. I got the cylinder head off without much problem. Now I have to take the head to the machine shop to have it resurfaced.
Similar Threads
  1. John Deere 1050
    By wilsonfam in forum Private Party Ads
    Last Post: 09-22-2011, 11:55 AM
  2. John Deere 1050
    By wilsonfam in forum John Deere Owning/Operating
    Last Post: 09-20-2011, 05:31 AM
  3. John Deere 1010 Exhaust Manifold- Gas
    By davidandlyndalong in forum John Deere Owning/Operating
    Last Post: 11-22-2010, 03:14 PM
  4. Buying Advice John Deere 1010 Exhaust Manifold- Gas
    By davidandlyndalong in forum John Deere Buying/Pricing
    Last Post: 11-05-2010, 01:38 PM
  5. John Deere 1250 Exhaust Manifold
    By Thunderchicken in forum John Deere Owning/Operating
    Last Post: 01-14-2009, 12:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
