Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Member schneidvt's Avatar
    Join Date
    Feb 2013
    Posts
    26
    Summerfield, NC
    Ford 1500, Kubota 4240, Ingersoll 2014
    Default Re: Ford 1500 Clutch Replacement
    Quote Originally Posted by puckgrinder85 View Post
    I would resufrace the flywheel too if you're putting a clutch in. Might as well do the job complete and do it once the right way.
    Im on the fence right now with resurfacing, it looks in pretty good shape so I think im going to just see how it goes. In my experience with automotive clutches you can do it about twice before you start running into problems with warping and I have no idea how many times this one has been done in the past. This project is on a tight budget to say the least so it'll have to be one of those things to take care of later if it becomes a problem.
    Jason
  2. #12
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    Quote Originally Posted by schneidvt View Post
    Jason
    Generally speaking, if the flywheel is in good shape and isn't warped it'll work fine.
  3. #13
    Silver Member DaButcher's Avatar
    Join Date
    Sep 2012
    Posts
    139
    TEXAS
    MF165 & Ford 1500
    Good deal schneidvt, thanks for the explanation. When I got my 1500 more than twenty years ago it showed nine hundred something and often wandered how many hours were actually on it. I've put about 1300hr on it, so it has at least 2256hr. Wish I could be of help with your clutch job, but haven't had to split mine yet. Pics and any info you post about the clutch job is appreciated.
  4. #14
    Gold Member jones6780's Avatar
    Join Date
    Nov 2008
    Posts
    344
    Lizella, Ga.
    Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
    The flywheel is plenty thick and would be hard to warp from heat, it could wear unevenly. If it looked decent, I would take a wood block and some 180 sandpaper to scuff the glaze off it.
    Russell
  5. #15
    Join Date
    Feb 2013
    Posts
    26
    Summerfield, NC
    Well, ran into my first big snag. The clutch kit I ordered came with the wrong parts included. Hopefully they can resolve this and get me the right parts. Looks like it'll be another couple weeks before I can get this thing back together.
    Ford 1500 Clutch Replacement-img_20130227_133523-jpgFord 1500 Clutch Replacement-img_20130227_133701-jpg
    Jason
  6. #16
    Join Date
    Feb 2013
    Posts
    26
    Summerfield, NC
    Also, they are telling me that the clutch disk will operate the same even with the reduced friction area, doesn't sound right to me. Any thoughts on how much this will effect holding power?
    Ford 1500 Clutch Replacement-img_20130227_133548-jpg
    Ford 1500 Clutch Replacement-img_20130227_133602-jpg
    Thanks, Jason
  7. #17
    Join Date
    Oct 2010
    Posts
    578
    WI
    '13 Yanmar Lx4100
    We've run into a lot of new ones where the friction material is smaller. I assume a differnt material. Should be a sheet in the clutch kit that explains it. Overall we've had no issues with them holding, just make sure its the right one for your application obviously. If its right for your application then its just one more reason to resurface the flywheel, the clutch disk wont be riding in the same area as the old style plate.
    On the flywheel resurface- You're talking 40$ to resurface a flywheel from a local engine builder, I dont see any good reason NOT to resurface it. I guess being this is my job I tend to do it the right way the first time, because the second time we are losing money. Its the same for new/ resurfaced rotors when installing new pads. I just dont like putting new pads on an old uneven rotor even when the customer doesnt want to resurface them for 15$ a pop. Doing it right the first time is just in my routine, but if you dont have the 40$ to resurface thats fine.
  8. #18
    Join Date
    Oct 2010
    Posts
    578
    WI
    '13 Yanmar Lx4100
    Quote Originally Posted by MasseyWV View Post
    You have nothing to lose by saying that. If it slips or what have you, he has to split the tractor again. 40$ insurance policy, the cheapest one you'll ever find. I'd be putting all the seals he can as well. Flywheel can look ok and still be warped, it doesnt take a lot.
  9. #19
    New Member
    Join Date
    May 2011
    Posts
    5
    Snohomish, WA
    Ford 1700
    Default
    I have split my 1700. I need to remove the flywheel. Anyone know how to lock the motor so I can pull the flywheel. It has just 1 2 1/2 inch bolt on the back of it.
  10. #20
    Join Date
    Feb 2013
    Posts
    26
    Summerfield, NC
    So it took me longer to get back to this project than expected but once again I think I have gotten myself beyond the tools I have availible to me. I was able to remove the flywheel nut but am unable to remove the actual flywheel. I bolted angle iron across the flywheel and tried to tap it off from alternating sides but am a bit weary that ill damage the bottom end bearings if I get too forceful. My current rig is that I modified the old pressure plate to act as a puller and am alternating with penetrating lube and propane torches under tension to get it loose. Am I missing something or should I continue this procedure and hope for the best.
Similar Threads
  1. Ford 600 Clutch Replacement
    By CECILSSTEEL in forum Ford Vintage Tractors
    Last Post: 10-22-2013, 12:08 PM
  2. Ford 7710 clutch replacement
    By sandman2234 in forum Parts/Repairs
    Last Post: 04-01-2013, 04:24 PM
  3. Ford 1500 clutch problem??
    By bigjayfromwa in forum New Holland Owning/Operating
    Last Post: 04-30-2012, 08:10 PM
  4. Ford 1500 Clutch Replacement
    By telfer in forum Parts/Repairs
    Last Post: 05-20-2010, 05:56 PM
  5. Ford 1700 Clutch Replacement
    By Piper Pacer in forum New Holland Owning/Operating
    Last Post: 02-05-2009, 02:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
