Results 1 to 10 of 22
02-20-2013, 08:30 PM #1New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Summerfield, NC
- Tractor
- Ford 1500, Kubota 4240, Ingersoll 2014
Ford 1500 Clutch Replacement
I am currently in the process of replacing the clutch on a 4x4 1500. I have sourced the clutch, pressure plate, and throwout but have been unable to locate a part # for the rear main seal. The flywheel seems to be in good condition with no gouges, are there any recomendations on other items to inspect or replace while I have the unit apart? There were no unusual noises before disassembly,just a little slip under heavy load, clutch was out of adjustment room, and after inspection there was some oil contamination to the disk. Tractor has a little over 6000 hrs on it. I appreciate any suggestions as this will be my first clutch replacement and have no manuals to rely on.
current progress
02-21-2013, 06:47 AM #2Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,515
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
Re: Ford 1500 Clutch Replacement
Click on this link: http://www.messicks.com/NH/65672.aspx
When the page appears, select "engine" in the menu at left. Then scroll down to crankshaft, and flywheel, and click on it. Look for #19 in the exploded view, and in the part description. Part number is listed there.
Just double check to make sure it is the right one.
02-21-2013, 08:05 AM #3
Check the front seal on the transmission while it is apart.
02-22-2013, 12:23 AM #4New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Summerfield, NC
- Tractor
Thanks for the info, should be able to start re-assembly next weekend. Might even get it right the first time, probably not but it's a good goal.
02-22-2013, 07:11 PM #5
02-22-2013, 08:08 PM #6Silver Member
- Join Date
- Dec 2009
- Posts
- 232
- Location
- madoc ont 30 t years
- Tractor
- and i just got a 580 c case backhoe real good shape got another kubota 2100 .. 2 - 684 IH 2 -8 N Ford had B275 IH MF # 50 work bull MF 35 all redone 65 mf 1750 kabota
if you have a little oil change out your seals .. i am in the same boat right now with a MF65 only i have split mine 3 times now and still leaking need to split one more time .. had my father helping me and it went together with a bind . after he left i pulled it back found why it was binding put back together and still leaked ... with the bind i think i took out the seals again .fun fun fun ...i got it down to 45 min to pull apart lol ..good luck with yours
JACK OF ALL TRADES MASTER OF NONE
02-23-2013, 06:26 AM #7Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
I would resufrace the flywheel too if you're putting a clutch in. Might as well do the job complete and do it once the right way.
02-23-2013, 07:50 AM #8
02-23-2013, 02:35 PM #9
02-24-2013, 10:57 PM #10New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Summerfield, NC
- Tractor
the previous owner told us it had about 4000 when we got it, I doubt he would give a number that high if he wasn't telling the truth or atleast trying to. I have no doubts that numerous things have been replaced since then, i just wanted to make sure I put it in there in case there were some items that aren't usualy replaced or checked except on heavily used equipment.
Jason
Similar Threads
Ford 7710 clutch replacement
By sandman2234 in forum Parts/RepairsReplies: 17Last Post: 04-01-2013, 04:24 PM -
Ford 1500 clutch problem??
By bigjayfromwa in forum New Holland Owning/OperatingReplies: 5Last Post: 04-30-2012, 08:10 PM -
By telfer in forum Parts/RepairsReplies: 2Last Post: 05-20-2010, 05:56 PM -
Ford 600 Clutch Replacement
By CECILSSTEEL in forum Ford Vintage TractorsReplies: 17Last Post: 05-17-2010, 12:32 PM -
Ford 1700 Clutch Replacement
By Piper Pacer in forum New Holland Owning/OperatingReplies: 4Last Post: 02-05-2009, 02:25 PM
