Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    9
    beecher city, il
    newholland tc55da
    Default slip clutch friction disc
    I bought a brand name 3pt stump grinder and after using for approximatly 100 stumps, slip clutch friction discs needed replaced. Pto reads comer t40 4005, dealer charged me over $100 for two this size they are 5.50" outside, 3 1/16" inside, app 1/8 thick. I have combed the net in search of aftermarkets to match, most close i came to this size cost from $10 t0 $20, only ones I found that matched, were $40 each disc. Any suggestions as where to findat reasonable price or has anyone bought a disc that has a smaller inside and cut or ground to fit?
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: slip clutch friction disc
    i've refaced them using the hard 1/8" masenite and 3m spray glue for disc pads and clutch linings...
    I tell ya.. it's not perfect.. but depending on application.. sure can work..
  3. #3
    Join Date
    Nov 2007
    Posts
    720
    PA
    Kubota L3130 HST 4x4
    It might be worth calling these guys.4 Series Drivelines | PaulB
    Will any of these work?
    Quality Farm Supply - Slip Clutch Discs
    Or this place...
    Agricultural PTOs
    Let everyone know what you find, so we can all learn.
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  4. #4
    New Member
    Join Date
    Sep 2012
    Posts
    9
    beecher city, il
    newholland tc55da
    Tried all three, all had disc 5.5" outside and 3" inside now to deternine if I can cut or grind down 1/16 on inside to make it 3 1/16". Thanks
  5. #5
    New Member
    Join Date
    Sep 2012
    Posts
    9
    beecher city, il
    newholland tc55da
    I'll sure give it a try on old discs. Thanks
  6. #6
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    post back what ya find.
  7. #7
    Join Date
    Nov 2007
    Posts
    720
    PA
    How about these. They are all 5.5" but slightly larger ID:
    Slip Clutch Friction Discs
    https://www.smalink.com/default.aspx...ode=919-FP5533
    Clutch Linings/ Fiber Disc for Metric PTO Shaft
    Replacment Slip Clutch Friction Disc 1805010 | eBay
    What kind of equipment is this shaft off of? Model #?
  8. #8
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,438
    Ararat Vic Aus
    G'day it is possible to make clutch plates bigger id and grind down od have had to do it for some older machines I have worked on over here BUT please be very CAREFUL some of these plates are made with ASBESTOS!!!! Please use a good quality mask and other appropriate safety gear when working with this stuff. Good luck
    Jon
  9. #9
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,578
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    I posted this a couple years ago:
    This Spring, during the annual Slipping of the Clutches festival, I noticed that one of the friction discs was missing some pieces - about 30% was gone. Good luck finding replacements locally - I wasted a perfectly good Saturday on that drill. A little patience and a charge to AgriSupply and my friction discs were on the front step in 4 days.
    My advice is to get a spare set now, so you can get it running quickly when you need it.
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  10. #10
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,307
    Missouri
    Kubota M9540, Ford 3910FWD, JD2210
    Sorry I can't help in finding new discs. But I'm wondering why they were worn out?? Maybe the clutch has been slipping a LOT. As with a brushcutter, I always loosen the clutch in the Spring and make sure it slips, then tighten and run a few minutes with a load. Then I stop and touch the clutch pack with my hand to see if it's warm or hot which would indicate it is constantly slipping. Tighten until it runs cool.
    Sorry for the hijack.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
Similar Threads
  1. Buying Advice Live PTO vs. Over-running Clutch vs. Slip Clutch
    By Beervangelist in forum Buying/Pricing/Comparisons
    Last Post: 05-05-2016, 03:36 PM
  2. Friction disc and pulley 446
    By Nort in forum Case / Ingersoll
    Last Post: 05-21-2011, 01:23 PM
  3. Slip clutch on rotary cutter may not slip: BAD??
    By beppington in forum Attachments
    Last Post: 05-09-2011, 09:26 AM
  4. New to friction clutch
    By Knight in forum Attachments
    Last Post: 04-01-2011, 10:15 PM
  5. PTO Slip Clutch Friction Plate
    By msquared100 in forum Parts/Repairs
    Last Post: 06-18-2009, 04:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
