the disc blades on the front left bar are all loose and wobble around, Im hunting partsView attachment 307636
Thank you man, I'm posting some more pictures. I have it off tractor now. all the others are tight. its just the one bar with problems. Looks like somebody replaced some parts and didnt get it back together tight. ill have the pics up soon now if you will take a look at them for me. Thanks again. And Im looking for a good place to start ordering part from.That looks like a standard flange bearing available at most hardware stores. You need to disassemble to determine axle size and condition of the axles. Ken Sweet
Also ... start soaking that axle nut with penetrating oil get a couple good sized pipe wrenches as well as a length of pipe ... sometimes the axle nut may even need heat to get it broke loose.
Small world ... I'm going to be in your area mid morning talking to a possible auction client. I don't think we've met ... if your an auction fan you've probably been to one or more of my auction sales.
Did you use the all thread as the axle? (The shaft that all the disc and disc spacers go on) ... I hope I read that wrong. The main shaft is a square axle and the disc have a square center to match the axle so they won't spin on the shaft.
