Results 1 to 3 of 3
  1. #1
    Gold Member chrisdvorak's Avatar
    Join Date
    Jul 2009
    Posts
    302
    RI
    too many
    Default case 580d fuel shutoff
    I need to change the fuel filters on my case 580d but can't seem to find the fuel shutoff knob, I've attached a pic that shows what I think is the drain for the tank and to the left is the fuel line to the primary filter but no shutoff?
    Attached Thumbnails Attached Thumbnails case 580d fuel shutoff-img_0189-jpg
    if you have checks, you have money.... right???
  2. #2
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,208
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Default Re: case 580d fuel shutoff
    That is definitely the fuel tank drain. The shut off valve SHOULD be on the left side (the side you get on). You should be able to reach it standing beside it. Follow the fuel line back away from the filters. It is back about as far as the front of the fuel tank, kinda' tucked towards the frame. I can just get to it, as my arms are kinda' big. Seems I had to reach behind a line of some sort, possibly the large one going up in your picture. Between it, and the engine block. I know if you look back from about the fuel filters, you can just barely see the tang on the valve. That somewhat oily line near the bottom of the picture should be your fuel supply line from the tank. Follow it towards the frame. And as mentioned, you should be able to reach it from the topside.
    d
    Just make sure you have about a half tank of fuel, or enough in the tank, to be above the bleeder cap on the secondary filter, or you'll never get the air bled out. Just did mine last Friday, on my 480C...
  3. #3
    Join Date
    Jul 2009
    Posts
    302
    RI
    too many
    thanks DJ54, I did find it right above the flywheel. it sure is a difficult place to get to.
Similar Threads
  1. Case 580D Operators Manual
    By F100Panel in forum Construction Equipment
    Last Post: 12-01-2011, 03:45 PM
  2. Backhoe Case 580D replacement motor
    By Dale Harrell in forum Case-IH
    Last Post: 07-10-2011, 09:59 AM
  3. 580D CASE STEERING
    By dugano339 in forum Hydraulics
    Last Post: 06-30-2011, 01:31 PM
  4. case 580d
    Last Post: 06-20-2011, 10:11 AM
  5. 580D case with thumb
    By Anonymous Poster in forum Owning/Operating
    Last Post: 01-13-2003, 09:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
